Some problems with installing inventor 10
Hello,
I cant install inventor 2010... I have an error message: "C:\DOCUME~1\User...\_AI5D.tmp\Setup.exe /s C:\Autodest\Ineventor_2010_SV\x86\SecondRun /Language en-us /SMS" What can I do? and how can I use 2010 inventor files in inventor 2009...? |
Re: Some problems with installing inventor 10
And as far as your install issue, I see your from Israel, but based on the little bit I highlighted on your error code, it looks like your trying to install an English-United States version, which is probably what is giving you problems. I read somewhere that Autodesk only gave out a US license this year. You should see if there is a location option when you download and install it, or just get in contact with Autodesk. Good luck! -Scott Last edited by scottydoh : 15-01-2010 at 15:43. |
i hope this is not the situation... in any case - can someone save the "stick" wheel in inventor 09 format? this is the only thing I can't find anywhere else...
Ill try and save a copy for you.
| Trouble With Installing Inventor 64bit Vista | BrAAndon | CAD | 24 | 28-01-2009 12:41 |
| Need Help Installing inventor with Firstbase | bkantor01 | Inventor | 0 | 24-01-2009 15:58 |
| Problems with Inventor | Sean Marks | Inventor | 2 | 26-04-2007 08:57 |
| Problems with transmission using Inventor 8 | Drew Hopman | Inventor | 4 | 10-01-2005 19:07 |
| Problems Installing Inventor | Adam Shapiro | Inventor | 8 | 17-01-2003 22:45 |
