Go to Post There were no heroes on the team, just everyone doing their part. - nuggetsyl [more]
Unread 15-01-2010, 19:24
ellisk ellisk is offline
FRC #1540
ellisk is on a distinguished road
Errors in Diagnostics: I/O unit not detected
On the Classmate dashboard, I'm getting the following errors in the "Messages" box, under "Diagnostics":
I/O unit not detected or not installed correctly.
No Change to Network Configuration: "Local Area Connection"
Does anyone know what these mean, how to resolve them, or if they're even important?
Thanks.
Unread 15-01-2010, 19:45
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Errors in Diagnostics: I/O unit not detected
Do you have the I/O unit programmed and connected? If not, that's why you get the message.
It means the network was already set up correctly, it's information only. It's more meaningful when you try to run the DS software on your own computer.
Unread 15-01-2010, 22:04
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Question Re: Errors in Diagnostics: I/O unit not detected
What do you mean by I/o unit?
could you describe it?
Unread 15-01-2010, 22:34
AKA: Jon
never mind i found it but is it necessary for running the ds?
Unread 15-01-2010, 23:42
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
It's optional.
Useful if you want to create your own control box, but there are analog and digital inputs aplenty on a joystick too.
Unread 16-01-2010, 00:25
AKA: Jon
OK thanks mark!
Changing Default Unit System Richard McClellan SolidWorks 6 28-02-2010 16:09
No robot diagnostics unobtainium-42 C/C++ 3 31-03-2009 09:50
Help: IFI loader not communicating with control unit red_alert_13 Programming 9 20-01-2006 17:30
Breaker Panel Diagnostics dm0ney Programming 4 29-03-2005 19:00
Linking Errors: "section '????' can not fit the section. ..." Astronouth7303 Programming 3 16-01-2005 21:36
