Go to Post GP isn't just a good idea, it's mathematically optimal. - Jared Russell [more]
Unread 01-16-2010, 07:01 AM
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Think About Protecting Your Battery!
This is a good time to start thinking about the battery on robots going over the bump. Batteries have a lot of mass and are full of heavy parts like the lead plates inside each cell. Although other threads have stated that the Crio can take a lot of abuse, the battery may need some crash protection. Please check the manufacturer's specification for drop force and plan accordingly.
While you are at it, make sure that you follow the electrical rules for securing the battery in the robot. Even if you have the best robot on the field, they are not going to let you play with your battery dragging on the floor.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 01-19-2010, 11:48 AM
fsgond's Avatar
fsgond fsgond is offline
Why aren't you throwing balls?!
AKA: Anthony
FRC #5484 (Memento Vitam)
Team Role: Coach
Rookie Year: 2007
fsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant future
Re: Think About Protecting Your Battery!
well said
Unread 01-19-2010, 01:29 PM
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
If I had a nickel for everytime I saw a team dragging a battery in my 8 years as a mentor...
One of the most deflating experiences a team can have is to be sitting there unable to move in the elims from an un-plugged battery, so please make a simple strap to keep it in place as a bare minimum. All you need to do is take some velcro and rivet it to your frame sandwitched between a couple thin sheets of Al. And for those of you that want a Martha Stewart tip for dressing it up, take the scraps of fabric from making your bumpers and put them on the adhesive section on the velcro.
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
Unread 01-19-2010, 01:35 PM
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Just a suggestion http://andymark.biz/am-0477.html The simplest things can change the whole game
Unread 01-19-2010, 04:31 PM
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Another concept you can do to hold it in place (we did it last year and it worked perfectly) - build a little "seat belt" for it. Simply buy a buckle like this:
, work in two short nylon straps, and you're set! We found that a simple pop-rivet was plenty to hold the ends of the belt in place, and with the buckle right on top of the battery it was extremely easy to undo when a battery needed to be replaced.
Unread 01-19-2010, 04:34 PM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We've used the plastic buckle for the past 3 seasons, it works great. Velcro is also a great idea. And the strap and block kit that AndyMark sells also looks very good.
I wonder about the shock loading thing....has anyone experimented with foam or other resilient materials? I wonder if the foam used in pool noodles would be good for this? It seems to be similar to one type of race car roll bar padding.
Unread 01-19-2010, 04:49 PM
Travis Hoffman's Avatar Unsung FIRST Hero
Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Travis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond repute
That sounds rather painful for Al.
Add another vote for the quick release plastic buckle. Search "48 Flips" on Youtube - yeah....we were using one of those buckle straps during that. No issues or damage at all.
Finally - please don't ever use your battery as the counterbalance of your arm. Yes, I've seen this on a FIRST robot. Yes, it was deemed legal. Why? I have no clue!
Travis Hoffman, Enginerd, FRC Team 48 Delphi E.L.I.T.E.
Encouraging Learning in Technology and Engineering - www.delphielite.com
NEOFRA - Northeast Ohio FIRST Robotics Alliance - www.neofra.com
NEOFRA / Delphi E.L.I.T.E. FLL Regional Partner
Unread 01-19-2010, 08:38 PM
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
http://www.youtube.com/watch?v=CjHMb55EXmY
I don't know if that is considered EPIC WIN or FAIL
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 01-19-2010, 09:15 PM
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
If memory serves, one year 116 asked if they could use additional batteries as counterweight. Although, knowing those jokesters, it might well have been in jest.
On topic, we used a zip tie. Every match we'd ziptie the connectors together and cut it loose at the end of the match. We tried a velcro strap, but it was always getting in the way, so we found zipties to be a less obnoxious solution.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 01-19-2010, 09:27 PM
yoshibrock's Avatar
yoshibrock yoshibrock is offline
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
Team Role: Mechanical
Rookie Year: 2007
yoshibrock will become famous soon enoughyoshibrock will become famous soon enough
Send a message via AIM to yoshibrock
Thanks for the advice. We usually make a little cradle for our battery out of aluminum L brackets. The cradle is riveted together and then bolted to the frame. On the shafts of the four bolts we put rubbers spacers to help absorb the shock. Then we fasten the battery in with velcro. It works great, and we've never had any problems with it.
There is no charge for awesomeness.
Am I a hero? I really can't say, but yes.
Unread 01-19-2010, 09:38 PM
Unsung FIRST Hero
Rookie Year: 1996
Guys,
I think you were missing the point. I am suspecting that robots coming off the bump this year will produce some serious g forces on the battery. In addition to the secure attachment, we may also need to consider some shock protection for the battery.
Al
WB9UVJ
www.wildstang.org
Unread 01-19-2010, 09:55 PM
MrForbes's Avatar
AKA: Jim
Guys,
I got it, I don't know if anyone else did....but thanks for the reminder again.
Unread 01-19-2010, 10:08 PM
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
If teams have any of the memory foam left over from the goals, that might be a wise material to help cushion the battery from g forces.
Al, I had an impression of both g force protection and securing the battery from your post. I have seen too many robots which are not secured down, and I am sure that you have more of the same in your years as an inspector.
Thanks for the insight Al!
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 01-19-2010, 11:24 PM
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Remember, this year securing your battery on the robot is not just a good idea. It is a requirement. Make sure you have read and understand the implications of Rule <R18>. Just having a cradle for the battery to rest inside is not going to cut it. The battery needs to be velcro-ed, strapped, buckled, tied, bolted, glued, zipped, or stapled in place so that it can't fall out when (not if) the robot turns upside-down.
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
  #15   Spotlight this post!
Unread 01-19-2010, 11:59 PM
IBdrummer's Avatar
IBdrummer IBdrummer is offline
AKA: Beau Muniz
FRC #5492 (Winners Circle Robotics)
Rookie Year: 2007
IBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of light
-dave
I think that is another implication about how robust the GDC wants the robots to be this year.
Question about battery placement itsme Electrical 7 02-11-2008 04:18 PM
pic: Something to think about... CD47-Bot Extra Discussion 27 07-11-2004 02:27 AM
Think about it Raul General Forum 8 04-07-2003 03:00 PM
think about it E. The Kidd CD Forum Support 2 12-01-2001 10:16 PM
One way to think about it. Joe Johnson General Forum 16 10-07-2001 09:21 PM
