Motor resistance
Do you think a CIM motor or window motor can hold an axle that holds 2 robots with out breaking?
P.S. sorry for the bad english, I'm from Israel ![]() |
Re: Motor resistance
The CIM will "back drive" when no current is applied, unless some mechanism to prevent this is implemented. I don't believe the window motor will back drive, but I do think you could potentially over-stress it. Consider a separate braking/locking mechanism.
yoav,
The CIM motor does not handle side loads. You will need to add external bearings to hold the weight you are suggesting in addition to some form of lock to prevent the robots from dropping when disabled. |
| Team Resistance Underground. . | wsansewjs | Website Design/Showcase | 2 | 19-03-2007 15:19 |
| pic: resistance winning | Nick 1523 | Extra Discussion | 1 | 12-03-2007 16:20 |
| Battery on-resistance | Frank Neuperger | Electrical | 4 | 22-01-2007 09:22 |
| Meet Team Resistance 86 | archiver | 2001 | 2 | 24-06-2002 00:54 |
