Go to Post we used to walk barefoot through five feet of snow to get to school, uphill both ways, with just barbed wire for mittens, and we liked it! - dlavery [more]
Unread 16-01-2010, 13:51
RookieWookiez's Avatar
RookieWookiez RookieWookiez is offline
Scouting Student Leader
AKA: Dane Potter and Others
FRC #3138 (Innovators)
Team Role: Scout
RookieWookiez is an unknown quantity at this point
Solenoid Question
Me and my team were playing around with the Solenoids the other night to see if it was a good idea to use it. But... The only problem we found with it is that the Solenoid is, well, annoying to work. The problem we were having with it is that when we pushed air through port 4, and we had been blocking up port 5, we built up pressure before trying to release it, and the air came out of port 1. But when we could try it again, not moving any parts around, air could come out of port 1 instead of blocking up in port 5 again.
We tried doing that a few times, even blocking most of one side of the Solenoid, but we still don't know entirely how it works. Anyone know if we're doing something wrong, like pumping air in through the wrong port?
Unread 16-01-2010, 16:37
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Solenoid Question
Most solenoid valves need a pilot pressure of at least 20psi to work properly.
Are you doing this by hand, with compressed air, or with a pressurized system?
Unread 18-01-2010, 18:35
Team Role: Scout
We were using a Pressurized system and we had the max of PSI in there (60).
Solenoid question from Israel Shomron1690 Rules/Strategy 2 21-01-2007 09:29
solenoid valves? brian1717 Pneumatics 2 07-01-2007 15:28
Question about Solenoid and default code waialua359 Control System 4 21-01-2006 18:21
Spike/Solenoid Question Dinush Electrical 4 14-02-2004 18:11
Fresno solenoid.... mike325 Technical Discussion 3 11-02-2003 07:50
