Go to Post The 2008 team is not the 2007 team and won't be the 2009 team. Every year is a new year and a new opportunity for growth and development as a FIRST team. It's very cool. - JaneYoung [more]
Unread 16-01-2010, 14:40
pjholmes pjholmes is offline
FRC #3189
pjholmes is an unknown quantity at this point
FRCDiagnosticWindow Error 1 at InvokeNode.vi
When running the FRCDiagnosticWindow.lvproj, we select the "Run Diagnostic Window" button, the Deployment Progress window opens and reports errors. When we close the window we get the error message:
Error 1 occurred at InvokeNode in PC.vi
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
cRIO has image v19.
Any idea what might cause this?
Thanks
Patrick Holmes
Mentor, Team 3189
Unread 17-01-2010, 00:10
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: FRCDiagnosticWindow Error 1 at InvokeNode.vi
These errors are the important one, not the one you posted. The one you posted only reports that there was errors during deployment.
MPLAB error: Error [1027] unable to locate 'serial_ports.h' rokenboker Programming 10 03-09-2009 16:29
LebView Error -- Error 1055 occured at Property Node in FRC Create Project.vi->FRC Wi RMS11 Programming 8 08-12-2008 18:20
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
