Team #1566 is wondering what exact specifications there are for having items hanging down from the robot. Is there a certain length it can be above the ground? Or is it basically if it fits under the robot it works.
Thanks, Mitch Guzman |
Re: items/devices/mechanisms hanging from robot
Don't let anything hang down so far that you get metal-to-carpet contact. That's about it.
Along with complying with all the rules about BUMPER PERIMETER, FRAME PERIMETER, etc. |
Im working with a rookie team an I'm wondering if hanging a chain for defense that is not touching the carpet except at the bump is within the rules
I believe that hanging chains/strings/etc constitutes an entanglement hazard as defined in Section 8 <R06> of the game manual.
Diana,
This is a risky idea on many levels. Objects extending outside the frame for more than two seconds, metal to carpet contact, entanglement, etc. Students need to look over the rules several times before they begin to see them as a sum of parts. Your first stumbling block will be your first practice match when the refs disable you for one of the above rule infractions. |
Here is what i believe is the relevant rule. Quote:
| Hanging Mechanisms | gorrilla | Technical Discussion | 17 | 15-01-2010 23:16 |
| Hanging from the bar: | Frank(Aflak) | Rules/Strategy | 8 | 22-02-2004 19:49 |
| Robots Hanging from the Floor | Todd Derbyshire | Rules/Strategy | 16 | 13-01-2004 14:10 |
| Robot Positioning Devices | austind27 | General Forum | 10 | 11-02-2003 21:58 |
| Robot Mechanisms Image Database | archiver | 2001 | 0 | 23-06-2002 22:14 |
