Go to Post But please, don't attempt to subvert the rules. It almost invariably becomes more trouble than it's worth. - Billfred [more]
Unread 17-01-2010, 00:47
ricechrisbtreat ricechrisbtreat is offline
Chris Barlog
AKA: Chris Barlog
FRC #2659 (Robo-Warriors)
ricechrisbtreat is an unknown quantity at this point
Question Laptop/Classmate/cRIO/bridge/router wiring help
Hi,
Is there a guide to hooking all of these things up, or is it just (educated) guess work? Because that's what we've been using. What I mean is which items are connected to what by Ethernet cables, and which type (crossover/regular)? BTW, We use a separate laptop (not the classmate) to upload code to the robot, so that should be factored in. Sorry for the stupid/ super basic question. Thanks in advance!
Thank you teams 207 and 973 for picking us on your alliance and allowing us to win the L.A. Regional!
Unread 17-01-2010, 08:48
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Laptop/Classmate/cRIO/bridge/router wiring help
Yes, there is a guide.
No, just guessing will result in damage that can get expen$ive.
For the guide, start at www.usfirst.org, click on the FRC link at top.
Or search the forum for more info
Good Luck.
Unread 17-01-2010, 08:58
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
It's kind of buried in the Getting Started manual. A sentence here, a sentence there.
There are several different ways to hook it all up, but typical setup would be:
  • Classmate -> router
  • programming PC -> router
  • router -> robot wireless bridge
  • robot bridge to cRIO
You can cable directly or setup the wireless to work on both computers to the router. Wireless for the classmate requires that the router have wireless g enabled in addition to N.
The router can also connect directly to the robot cRIO via Ethernet cable.
bridge/cRio communications sporadic nathanww FRC Control System 23 22-02-2010 15:00
cRIO configuration issue- serial connection to laptop Torbots 1197 FRC Control System 5 28-01-2009 22:28
Laptop not finding router popo308 FRC Control System 7 16-01-2009 14:09
Can not connect bridge and router wirelessly team877 Programming 4 08-01-2009 00:18
cRIO/Driver Station output to laptop smcmahon FRC Control System 3 14-12-2008 13:51
