Go to Post Steal from the best, and then invent the rest! - dlavery [more]
Unread 17-01-2010, 10:45
xSpongeX xSpongeX is offline
FRC #3369
xSpongeX can only hope to improve
What is the weight and height limit for FRC 2010 Robot?
Does anyone know the weight and height limit for the robot in FRC 2010??
Thanks!
Unread 17-01-2010, 10:48
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: What is the weight and height limit for FRC 2010 Robot?
According to the rule book, page 12.
<R10> During the MATCH, the ROBOT will assume one of two operating configurations. When in each configuration, the ROBOT shall fit within the limits shown below (note: these limits are defined in reference to the ROBOT, not the FIELD).
Maximum Horizontal Dimensions
Maximum Height
Maximum Weight
NORMAL CONFIGURATION
Rectangular space no more than 28 inches (71.12cm) by 38 inches (96.52cm)
60 inches (152.40cm)
120 pounds (54.43Kg)
FINALE CONFIGURATION
84 inch (213.4cm) diameter vertical right cylindrical volume
90 inches
(243.8cm)
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 17-01-2010, 12:18
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Thanks!
I'm not getting on to you, but please read the manual. If you did not read the rule for height and weight, it's pretty apparent that you have not read the manual very well or at all.
This year the rules are very tricky and need to be read carefully before you or your team decides on any final design.
The manual can be found at: http://usfirst.org/roboticsprograms/...nt.aspx?id=452
Also, check this page every few day for rule changes and clarifications: http://usfirst.org/roboticsprograms/...nt.aspx?id=450
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
What is the essay for the Limit Switch? reader_girl932 Kit & Additional Hardware 0 11-02-2008 16:55
Is there a limit on Robot height in opponents home stretch? veeveecai Rules/Strategy 3 30-01-2008 20:49
VEX Limit switches for FRC Robot??? cdennisxlx2 Technical Discussion 5 18-11-2006 13:37
What is the FRC Robot Controller Power Consumption amateurrobotguy Electrical 4 02-03-2006 00:23
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
