Go to Post "automated chaos" nuff said. - Jferrante [more]
Unread 17-01-2010, 12:08
dnrobotics11 dnrobotics11 is offline
FRC #2589
dnrobotics11 is an unknown quantity at this point
classmate problems
hey everyone,
for some reason the classmate freezes whenever i switch between the driver and the developer login. it goes into some weird state between off and on where the screen is black but the green lights say it is on. has anyone else experienced this problem?
thanks
Unread 17-01-2010, 12:52
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: classmate problems
I've seen that.
I had to cycle power to get it back working.
Unread 17-01-2010, 14:09
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
I've had it a couple of times. It seems to happen when developer is logged in while logging off driver. Winkey-L gets me out of driver just fine (It's switch user. Much faster than logging out then in) and if I need to logout driver I usually end up doing it from control panel on the developer account
Unread 18-01-2010, 00:59
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
Switch User is dangerous on the classmate... it leaves the Driver Station app running in the Driver account. If you forget and try to run it in the developer account too, then it won't work. It can lead you, or more likely your teammate, down wild goose chases looking for why there is no communication, so I recommend avoiding it altogether.
Unread 18-01-2010, 02:02
I'd recommend using the Exit button when you want to leave the Driver account. If you want to develop and drive, use the developer account and run the DS from the Start menu.
Greg McKaskle
Classmate PC lon.bushweiler Control System 8 22-01-2010 14:46
Classmate Issues ROFLcopter NI LabVIEW 10 16-01-2010 21:56
Classmate MachineSMMC NI LabVIEW 10 15-01-2010 13:47
classmate help!!! a kenny03 General Forum 1 13-01-2010 20:33
Problems Interfacing '10 Control System w/ Classmate 1951-44U FRC Control System 14 11-01-2010 06:30
