Go to Post A FIRST adage: You can make an Offensive robot play defense more effectively, than you can make a Defensive robot play offense. - Enigma's puzzle [more]
Unread 17-01-2010, 15:52
TPNigl TPNigl is offline
FRC #0069 (Team HYPER)
Rookie Year: 2007
TPNigl is an unknown quantity at this point
Camera not sending image to Classmate?
Right now we have compiled the Circle Tracker Demo to the CRio. We have the crossover cable connected from the camera to port 2 on the CRio, and another crossover cable connected from port 1 on the CRio to the classmate.
There is no image coming up at all either and we are very confused. Any help?
Unread 17-01-2010, 16:03
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: Camera not sending image to Classmate?
you don't need a crossover to connect the cRIO to the Classmate.
what Language?
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 17-01-2010, 17:59
frcchile's Avatar
frcchile frcchile is offline
FRC #2576
frcchile will become famous soon enough
what Language?
Brother you need unistall and install again FRCLabVIEWUpdate2.0for2010 and FRCLabVIEWUpdate1.0for2010 I had the same problem and it worked
Good luck
Unread 17-01-2010, 21:05
Rookie Year: 2007
Yea, we just fixed the Dashboard, which wasn't updating. We didn't have a chance to check to see if the camera will send any, but we will tomorrow. I will update tomorrow as well. Oh, and we're coding in Java.
Unread 18-01-2010, 12:15
Rookie Year: 2007
I updated the dashboard, but the camera is still not sending images. However, I am not getting an error message saying Timeout in Communications, so I have no clue what is exactly happening.
Unread 18-01-2010, 18:21
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
You do have the video display on-off switch turned on, right? It's the little control at the bottom of the dashboard video window. It'll show a bright green highlight when you set it to the "on" state.
Unread 18-01-2010, 18:51
Rookie Year: 2007
Yea, we do. We got the dashboard to say "camera running e", but still no camera images. Any ideas?
Unread 18-01-2010, 23:26
I don't think I saw mention of configuring the camera. There is a utility to create an FRC user and FRC password on the camera. Without those, the camera will simply return errors, and it may be that the WPI camera libs hide the errors -- not sure.
Connect the camera to the PC, set the PC IP to 192.168.1.1, and run the camera setup utility. Alternately, you can browse to 192.168.1.90 and do the configuration by hand. You can also do this to verify the camera works correctly. Once you log into the camera, you can view images, change settings, etc.
Greg McKaskle
Unread 20-01-2010, 20:46
Rookie Year: 2007
We did configure the camera and tried setting the username and password to FRC, but that still did not fix it.
2011 Pit Crew:
2011 CT Xerox Creativity Award
HYPER Alumni
Unread 20-01-2010, 20:51
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Rookie Year: 2000
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Run the Driver Station update to uninstall the old Driver Station, then run it again to reinstall it. Just updating it (without the uninstall) sometimes doesn't work.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 20-01-2010, 21:14
Rookie Year: 2007
We did uninstall the old Driver Station. Sorry to be very unhelpful to my situation. Is there anything else I can add that would make this easier?
2011 Pit Crew:
HYPER Alumni
Unread 20-01-2010, 21:31
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
Could you post your code that the cRIO is running?
Unread 20-01-2010, 21:39
Rookie Year: 2007
Ok, well, I'm not at robotics now, so I'll post it tomorrow. Thanks guys!
2011 Pit Crew:
HYPER Alumni
Unread 21-01-2010, 14:37
mswalker mswalker is offline
Mentor
FRC #2583 (Westwood Robotics)
mswalker is on a distinguished road
This post may help. I haven't tried it yet but it appears to describe the problem we are having:
http://www.chiefdelphi.com/forums/sh...13&postcount=3
  #15   Spotlight this post!
Unread 22-01-2010, 17:05
Rookie Year: 2007
We did fix that and we have that update complete.
Here's our code
Code:
import edu.wpi.first.wpilibj.GenericHID.Hand;
import edu.wpi.first.wpilibj.Gyro;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.PIDController;
import edu.wpi.first.wpilibj.PIDOutput;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SpeedController;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.camera.AxisCamera;
import edu.wpi.first.wpilibj.camera.AxisCameraException;
import edu.wpi.first.wpilibj.image.ColorImage;
import edu.wpi.first.wpilibj.image.NIVisionException;
import edu.wpi.first.wpilibj.DriverStationLCD;
//   import edu.wpi.first.wpilibj.samples.CircleTrackerDemo.TrackerDashboard;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class CircleTrackerDemo extends IterativeRobot {
    double kScoreThreshold = .01;
    AxisCamera cam;
    TrackerDashboard trackerDashboard = new TrackerDashboard();
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
    public void robotInit() {
        Timer.delay(10.0);
        cam = AxisCamera.getInstance();
        cam.writeResolution(AxisCamera.ResolutionT.k320x240);
        cam.writeBrightness(0);
     * This function is called periodically during autonomous
     * This function is called while the robot is disabled.
    public void disabledPeriodic() {
     * This function is called at the beginning of teleop
    public void teleopInit() {
    boolean lastTrigger = false;
    DriverStationLCD.getInstance().println(DriverStationLCD.Line.kUser2, 1, "Starting Camera Code");
    DriverStationLCD.getInstance().updateLCD();
    Timer.delay(1.0); //Wait one second so user can see starting message
     * This function is called periodically during operator control
            try {
                DriverStationLCD.getInstance().println(DriverStationLCD.Line.kUser2, 1, "Camera Running     ");
                if (cam.freshImage()) {// && turnController.onTarget()) {
                    ColorImage image = cam.getImage();
                    Thread.yield();
                    Target[] targets = Target.findCircularTargets(image);
                    Thread.yield();
                    image.free();
                    if (targets.length == 0 || targets[0].m_score < kScoreThreshold) {
                        System.out.println("No target found");
                        DriverStationLCD.getInstance().println(DriverStationLCD.Line.kUser2, 1, "Not Found              " );
                        Target[] newTargets = new Target[targets.length + 1];
                        newTargets[0] = new Target();
                        newTargets[0].m_majorRadius = 0;
                        newTargets[0].m_minorRadius = 0;
                        newTargets[0].m_score = 0;
                        for (int i = 0; i < targets.length; i++) {
                            newTargets[i + 1] = targets[i];
                  } else {
                        DriverStationLCD.getInstance().println(DriverStationLCD.Line.kUser3, 1, "Pos X: " + targets[0].m_xPos );
                        DriverStationLCD.getInstance().println(DriverStationLCD.Line.kUser4, 1, "Pos Y: " + targets[0].m_yPos );
                        System.out.println(targets[0]);
                        System.out.println("Target Angle: " + targets[0].getHorizontalAngle());
            } catch (NIVisionException ex) {
                ex.printStackTrace();
            } catch (AxisCameraException ex) {
It's just the basic default code for the CircleTrackerDemo
2011 Pit Crew:
HYPER Alumni
Getting Camera Footage on the Classmate CRASH999 FRC Control System 6 23-01-2010 12:29
Dashboard not appearing on classmate railerobotics Programming 2 20-01-2010 15:42
Java Camera Video on ClassMate Thomas4019 Java 8 16-01-2010 00:18
Classmate not loading Dashbaord on bootup gokul Control System 2 13-01-2010 10:34
[not-FIRST] Camera Image Processing Greg Marra Programming 11 11-03-2008 21:10
