completely confused (classmate isue)
Whenever we try to run the Basic FRC cRIO Robot Project (no edits to code) and then move the joysticks nothing happens. And in the drivers station program the three lights are green (Stop button, Robot Code, and the other one that slips me at the moment). In the errors section it says something about lack of communication with the camera.
Setup Test board wired to specs from here under Hardware Documentation with one sidecar and no signal light. Then off of the classmate is the 4 port hub (red and black usb in) and an ethernet cable going to the cRio (note no I/O). On the classmate Labview update and drivers station update applied (from above link, under software section) with nicyapi.dll added to windows/system 32. Any ideas. |
Re: completely confused (classmate isue)
I assume you re-imaged the cRIO with v19?
How are you downloading the code? Use "Run as startup" rather than "Run" for now. I also assume you clicked Enable on the Driver Station? What is the status LED on the Digital Sidecar doing - off/solid/blinking? There is a bug with the Dashboard install, so that can be double checked if you're depending on it to show responses. You don't need the red USB plug from the USB Hub (doesn't hurt either). That's for greater power, but the black plug alone gives it all you need. Last edited by Mark McLeod : 18-01-2010 at 09:44. |
The Basic FRC cRIO Robot Project was the name of the project from last season. Can you post the version of LV you are running, and the version of the image on the cRIO.
The LV version comes from the Help>>About screen. The cRIO version from the DS Diagnostics tab. Greg McKaskle |
cRio version is v19
LabView version is 8.6.1 Digital Sidecar lights all solid green |
we (team 379) are getting a 44003 error (camera error) is what i think is our problem
This week that problem has usually been due to an older version of the Dashboard program that doesn't work with the camera code on the cRIO and doesn't get replaced when the Driver Station Update is installed.
Two solutions to that problem are:
Tried 1 working on 2 thanks even if it doesnt work
if someone could close this thread im done with it (dumbdude1994 was unprofessional so i switched it to this user account if someone reads this and knows how to delete an account tell me please)
thanks for all of the help |
| How many teams will have to completely reconfigure there drive train | BlackBird11891 | General Forum | 11 | 04-01-2009 19:51 |
| Completely new to programming robots... | Comatose | Programming | 4 | 19-09-2008 19:22 |
| Camera code completely turning off all PWM's | Horohoroboarder | Programming | 10 | 10-02-2007 19:16 |
| And now for something completely Different... What is love??? | Robby O | Chit-Chat | 81 | 17-08-2001 14:16 |
