Go to Post Nominate your mentor for WFA, it's the best way to say 'Thank You'. - Brandon Martus [more]
Unread 17-01-2010, 21:34
ericzundel ericzundel is offline
Mentor
AKA: Eric Ayers
FRC #1795
ericzundel is an unknown quantity at this point
Need specs to make 2010 FP Gearbox coupler
It looks like the gearbox that goes with the FP motors did not come with a plastic coupler this year. (or did I miss something?) If so, I need to make something for our team using my tools at home, and I won't be able to get access to the gearbox itself until Tuesday.
Can anyone with access to a gearbox whip out some calipers and give me the ID and OD of the output coupler of the gearbox?
Thanks,
-Eric.
Unread 17-01-2010, 21:59
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
Re: Need specs to make 2010 FP Gearbox coupler
HobbyMasters sells them:
I am almost sure this is it: http://www.hobbymasters.com/powerwhe...4460-2249.aspx
Sorry, I don't have one available to measure.
Unread 17-01-2010, 22:14
Mentor
AKA: Eric Ayers
FRC #1795
Thanks for the link, I sent Hobbymasters a message with my follow up question which is, will these parts fit the gearboxes this year? The output pinion has 16 spokes while these hubs appear to be made for 10 spokes.
Unread 17-01-2010, 22:20
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
A round slug can be used in pretty short order. You can bore/broach it for whatever you are mating. I did a white paper over the summer that covers that plus a number other uses for the FP gearboxes. Skip to the end of it for what you are looking for. http://www.chiefdelphi.com/media/papers/2284
Mark
Brick walls are for other people. - Randy Pausch
Unread 18-01-2010, 08:40
Mentor
AKA: Eric Ayers
FRC #1795
Thanks Mark,
Great resource - thanks for sharing. Our team is mostly rookies, and I am passing on this whitepaper to them. The coupler made from a slug and a screw is exactly what I had in mind.
Now, If I only had those dimensions, I could machine it and bring it to the team tomorrow (they don't have a lathe at school yet.)
Unread 18-01-2010, 09:41
kramarczyk's Avatar
Quick measurement on an old one gives me 1.483-1.586". I used a 1.5" diameter slug last year, no lathe required. Good luck!
Mark
Unread 18-01-2010, 18:20
Mentor
AKA: Eric Ayers
FRC #1795
Many thanks
2010 Denso WIN motor specs Jonnadiah Motors 12 01-02-2011 20:04
2010 Mabuchi Motor Specs.... PhilBot Motors 13 27-01-2010 19:38
AndyMark CIM Planetary Gearbox Torque Specs Needed KTorak Technical Discussion 4 17-01-2008 18:53
Need Help: Build/Make Error ZeoFateX Programming 9 04-02-2004 10:56
Specs for drill motor gearbox? archiver 2000 4 23-06-2002 22:36
