Go to Post Hype levels are reaching critical levels... - wjd13 [more]
Unread 18-01-2010, 13:09
Bill Taylor Bill Taylor is offline
FRC #0388
Bill Taylor is an unknown quantity at this point
Motor limit for Denso 2010?
I know there is a motor limit of 5 CIM's this year but is there a limit on the number of Denso motors that can be used on a robot?
Unread 18-01-2010, 13:11
Joe Johnson Joe Johnson is online now
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Re: Motor limit for Denso 2010?
Just the 2 left hand and 2 right hand motors in the KOP. The rules do not add extra ones so that is all you get.
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Chris is me's Avatar
AKA: Pinecone
Yes, you can only use the Denso motors received in the Kit of Parts.
Unread 18-01-2010, 14:52
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
<R52> Motors specifically permitted on 2010 FRC ROBOTS include:
A. All motors, actuators, and servos listed in the 2010 KOP,
B. An unlimited number of COTS servos with a maximum output torque of 55 oz-in and maximum rotational speed of 100 rpm at 6 Vdc (e.g. HITEC model HS-322HD or HS-325HB servos, as provided in the KOP),
C. An unlimited number of FIRST Tech Challenge (FTC) servos (HITEC HS-475HB servos),
D. One, two, or three additional 2½” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the KOP. This means that up to five, and no more, 2½” CIM motors can be used on the ROBOT.
E. Identical one-to-one SPARE PARTS for motors, actuators, and servos provided in the 2010 KOP that may have failed or become damaged.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 18-01-2010, 18:51
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Also, to be clear, the rule is not 4 Denso motors but THE FOUR IN THE KOP -- that means 2LH and 2RH motors. I've inspected teams that had traded with another team because for one reason or another they wanted/needed all the same hand motors on their robot.
The performance may be the same*, but the rules are clear.
For what it's worth.
Joe J.
*well, actually often this is not quite true for most handed motors. They usually start exactly the same, but they often acquire slight biases or drifts over the years as tools wear, etc -- still in spec but one hand is almost always different than the other by the end of production.... ...but I digress...
Mentor
Team #88, TJ2
2010 Denso WIN motor specs Jonnadiah Motors 12 01-02-2011 20:04
What is the weight and height limit for FRC 2010 Robot? xSpongeX Rules/Strategy 2 17-01-2010 12:18
Optical encoder for denso window motor? jaredtkatz Motors 0 04-02-2009 16:10
Looking for Nippon Denso Motor connectors Schneider Motors 6 06-02-2007 00:51
Coupler for Denso Motor nlknauss General Forum 1 05-02-2007 17:20
