Go to Post But please, don't attempt to subvert the rules. It almost invariably becomes more trouble than it's worth. - Billfred [more]
Unread 18-01-2010, 13:15
Techgirl675's Avatar
Techgirl675 Techgirl675 is offline
FRC #0675
Techgirl675 will become famous soon enough
Send a message via AIM to Techgirl675
Question Bump Size Changed?
As seen on the Team Update 2 (http://www.usfirst.org/uploadedFiles...Update%202.pdf) The bump height has been changed, does this mean that the length of the base is different too to accommodate the angle? Our team has not been able to find out, here is an excerpt-
"Two BUMPS are located at approximately one-third of the length of the FIELD. Each BUMP is 13¼ inches high off the FIELD surface, 12 inches wide at the top, and extends across the spaces between the TOWER and the Guardrail System."
Unread 18-01-2010, 13:17
chmconkling's Avatar
chmconkling chmconkling is offline
Jack of all groups. Master at most.
AKA: chris
FRC #2363 (Triple Helix)
Rookie Year: 2007
chmconkling is an unknown quantity at this point
Re: Bump Size Changed?
They just adjusted it so with all the carpet and materials it now 13.25
Unread 18-01-2010, 13:36
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
This was never changed. The bump has always been 13.25 as per the released field drawings. There was a reference in the game animation/ quick game description which said 12 inches. If you built your bump to the plans you should not have to change anything.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 18-01-2010, 13:52
RoboTigers1796 RoboTigers1796 is offline
FRC #1796 (RoboTigers)
RoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of light
The actual size of the bump was always 13 1/4". If you built your bump using the official game drawings then you shouldn't have any problems, as those end up being 13 1/4". For some reason though the manual stated that the bumps were 12" high. The update just adjusted the manual to the real height of the bump. As for if the length changed, well it didn't because the bump never changed. If you built your bump to 12" high though, its possible. We're locked out of the shop today but I'll be happy to measure our bump for you if you'd like (which is the right height).
Check out the official drawing below. A 12 7/16" "rib"(i.e. support) with a 3/4" piece of ply lying flat on top of that to complete the top of the bump adds up to just under 13 1/4" (13 3/16 inches is the accurate height if you want to get specific). The manual was just wrong for a while.
EDIT: yeah, what Greg said.
2014 Attended: NYC Regional, SBPLI Regional NYC Regional- Imagery Award in honor of Jack Kamen
2013 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- Gracious Professionalism Award sponsored by Johnson & Johnson,SBPLI Regional- #4 Alliance Captain & Regional Winner- With our impeccable alliance 358 and 3171
2012 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- #7 Ranked Seed & Semi-Finalists, SBPLI Regional- #3 Seed & Regional Winner- With our very awesome alliance 527 and 870, Industrial Design Award sponsored by General Motors
2011 Attended: NYC Regional, SBPLI Regional SPBLI Regional- Xerox Creativity Award and #5 Alliance Captain
2009 Attended: NYC Regional, FIRST Championships NYC Regional Winner- With our amazing alliance 1807 and 56
Unread 18-01-2010, 16:24
KGood's Avatar
KGood KGood is offline
Capt'n
AKA: Kevin
FRC #2134 (Aztec Pirates)
Team Role: Leadership
Rookie Year: 2007
KGood is an unknown quantity at this point
They just corrected some confusion about the carpet's effect on the drawings. The height is in fact 13.25", and can be confirmed using some basic SOH-CAH-TOA on the other dimensions.
2007: Rookie All-Star Award
2008: #2 of 54 in AZ Regional
The bump before the bump Jeffy Rules/Strategy 2 16-01-2010 07:25
Dimension of Bump 5n1p3r Rules/Strategy 7 15-01-2010 00:51
Line or Bump? Swathi General Forum 2 05-01-2008 16:08
A Changed F.I.R.S.T Vin211 General Forum 0 26-09-2001 22:39
