Go to Post Defense will be everybody's part time job, not their career. - Wayne TenBrink [more]
Unread 19-01-2010, 22:02
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Frame design question
Originally Posted by Vikesrock View Post
A ball is either possessed or not, it can't be lightly possessed or sort of possessed.
Poltergeists notwithstanding
Unread 20-01-2010, 00:54
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
I was thinking the same thing, Don. Anyone offering to exorcise a possessed ball? Or is it cheaper just to replace it? #5s are too small to be exercise balls, right?
Unread 20-01-2010, 01:41
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
What if frame is seriously convex to the point where it is curves a pocket into itself, like an island atoll and having an opening on the wide side just larger than a ball? Would the bumper have to wrap both the outside and the inside "shore" of the "lagoon"? Could several balls be rolling around inside the lagoon area without being considered possessed, or having penetrated more than 3" into the frame zone? Would all the robot's H/W have to be built up ONLY within vertical space directly above the atoll shaped frame, or could some hardware protrude into the space above the lagoon? Why would there even need to be a bumper inside anyway, since no impact could ever happen there, and only "topologically" it is still the "outside" of the frame?
Kind of tricky getting a shooter concept to fit with this scheme for sure.
-RRLedford
Unread 20-01-2010, 07:06
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
-RRLedford
You would have to have a bridge across the mouth of the lagoon to attach your bumpers to, to meet <R07-M> and associated Fig 8.3. Note that the balls will still fit under the bumper attached to such a bridge. Therefore if the lagoon is more than 3" deep, you will violate <G46> and <R19>.
I would suggest spending a few more hours digesting the manual before you finalize your designs. You seem to have missed a few key rules.
(since 2004)
Unread 20-01-2010, 15:06
Zanfardino2892's Avatar
Zanfardino2892 Zanfardino2892 is offline
AKA: Mark Zanfardino
FRC #2892 (Hottie Botties)
Team Role: Mechanical
Zanfardino2892 is an unknown quantity at this point
-RRLedford
Any convex part of the frame will not be considered as the frame perimeter, if you have a convex are you want the ball to sit in the ball may only go 3" past the line created by wrapping a string about the corners of your robot, that is what defines the frame perimeter
Unread 20-01-2010, 15:18
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
From the definitions at the beginning of Section 8...
FRAME PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS attached) that are within the BUMPER ZONE. To determine the FRAME PERIMETER, wrap a piece of string around the ROBOT at the level of the BUMPER ZONE - the string describes this polygon.
The string in your scenario bridges the lagoon and crosses the island.
Al
WB9UVJ
www.wildstang.org
________________________
Robot Design: Frame Perimeter? IamMisplaced Technical Discussion 7 17-01-2010 15:03
pic: Frame Design Shira Extra Discussion 10 01-02-2009 14:06
robot design question Otaku Rules/Strategy 29 05-01-2009 19:21
pic: 1305 Frame design with trannies CD47-Bot Robot Showcase 19 25-09-2004 01:13
a web design trivia question robot180 Website Design/Showcase 5 17-10-2003 19:46
