Go to Post However, as a philosopher, while you need math, you can probably talk your way out of it. - sciguy125 [more]
Unread 18-01-2010, 17:56
erichahn525 erichahn525 is offline
FRC #0619
erichahn525 is an unknown quantity at this point
hook up ADXL345 to cypress breadboard at driver station
I am trying to use an accelerometer at the driver station as a unique controller. I am fairly new to programming and this is a little past my experience. If there is anyone out there that knows how to get data output from the ADXL345 (accelerometer issued from FIRST) through the CY8C3866AXI-040 (Arduino like micro controller) onto the driver station computer I would be very thankful.
ANYBODY?????
Unread 18-01-2010, 18:34
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: hook up ADXL345 to cypress breadboard at driver station
FYI, there is already a 3 axis accelerometer built into the Cypress FirstTOUCH board.
Unread 18-01-2010, 18:37
FRC #0619
But the problem is that i cannot use that accelerometer because i need the accelerometer to be seperate.
Unread 18-01-2010, 19:01
Rookie Year: 2000
Ok, I just wanted to make sure you weren't overlooking a really easy solution to your problem.
Unfortunately, there isn't a good way to do exactly what you are asking for. Neither legacy nor extended modes offer any of the serial communication methods necessary to talk to an ADXL245. Since the rules prevent you from modifying the code on the cypress board (if used at the driver station), you can't add them either. Bummer.
However, you do have a bunch of analog inputs. You could easily wire in an analog accelerometer, such as the ADXL335 that was in the 2009 KoP.
Unread 23-01-2010, 12:22
FRC #0619
Thanks a lot for your help, i'll look into the analog accelerometer. My team was taking about the same thing you are talking about... only a few years till FIRST will let us program the cypress as much as we want
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Driver station... the man Control System 16 06-01-2010 21:06
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
driver station corps FRC Control System 5 06-08-2009 20:44
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
