Go to Post When you are at the regional no one cares if you are a rookie. You are a part of the family. - scitecteach [more]
Unread 18-01-2010, 18:34
meastman meastman is offline
FRC #1245
meastman is an unknown quantity at this point
CIM Shaft Spacers
The spacers that came with the kit for putting the sprocket on the toughbox shaft do not fit with the key. Have any other teams had this problem? I guess that we'll just cut down the spacers so that they will fit.
Unread 18-01-2010, 18:54
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
Team Role: Mechanical
Rookie Year: 2007
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: CIM Shaft Spacers
My team just ground down the end of the key about a 1/16 of an inch. If you cut the spacer the sprocket will wiggle, I'd cut the key instead. The key doesn't have to be the full length of the sprocket, just as long as its pretty close.
Unread 18-01-2010, 19:02
FRC #1245
Good point. That makes sense
Unread 18-01-2010, 22:21
caincteam2777 caincteam2777 is offline
FRC #2777
caincteam2777 has a spectacular aura aboutcaincteam2777 has a spectacular aura about
well the class i tought we just used needle nose to forced it in there. wont have problems of it falling out
15T CIM Shaft Pinion Gear (DeWalt project) craigboez Technical Discussion 7 06-01-2010 16:58
Help: Bevel Gear Mounted On CIM Shaft? 854 bears Motors 16 24-07-2009 13:50
CIM motor shaft extender (adapter) Arkorobotics Motors 9 08-02-2006 06:53
CIM motor shaft Coupler Epot86 Motors 13 14-01-2006 22:05
