Go to Post For Pete's sake, don't concentrate on the entry itself... concentrate on what your team is doing to make an impact in your community. - Andy Baker [more]
Unread 21-01-2010, 10:53
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
Trapped under a pile of MECANUMS :P
AKA: @doctorfogarty
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
Re: So i have another problem >.<
I put that into my code last night, i'm going to try it today. It seemed the 2nd joystick was not in the Begin.vi that might have been the problem. and i set the open jaguar reference in the begin.vi as well.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 21-01-2010, 11:00
Matt95's Avatar
Matt95 Matt95 is offline
Matt the Programmer
AKA: Matt
FRC #1743 (The Short Circuitous)
Rookie Year: 2010
Matt95 is an unknown quantity at this point
Lightbulb Re: So i have another problem >.<
Originally Posted by Tanner View Post
From my experience, Joe's answer explains the problem. Otherwise, I don't see anything else that is wrong.
You could open all your motors/joysticks in Teleop.vi, but it gets complicated in just setting that up.
-Tanner
While Im not exactly sure about your problem, but i recommend removing all connection with the right control and seeing if the left motor works (by doing what it originally was suspost to do.) if the left control still isn't working, then the left control probably has a malfunction of some sort. In that case, you should get a new left control.
Unread 21-01-2010, 21:44
AKA: @doctorfogarty
ok so i've definatly got a problem, i took the right motor out of the code and set it to the y axis of joystick 1. AND it's doing the same thing and it's running both motors, i tried Joe's idea NOTHING IS WORKING. O.o ....
John Fogarty
Unread 21-01-2010, 22:06
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Could you explain in detail how you are deploying the program?
Unread 21-01-2010, 22:28
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
I would try separating out those constants on the axis it shouldn't change anything i know but thats what caused ours to do that.
Unread 21-01-2010, 22:37
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
Have you looked at the Diagnostics tab of the driver station? There is a window that will show all your errors there. Please tell us what errors you see. It's best to clear the error list, then run it, so you can get a clear picture of what errors happen in a single run.
Unread 22-01-2010, 10:42
AKA: @doctorfogarty
I had so many errors it wasn't funny when i replaced Arcade Drive with tank drive. I tried Arcade and it still screwed up but the errors were gone. What i do is start a new Robot Project I build it and set it as the startup. I edited the tele-op File to use jostick, watchdog and Open motor references from the begin.vi, I changed the Arcade drive to Tank Drive and i set the 2 get axis's to Axis 2 and axis 5 because i'm using the Daul Action Gamepad. then i took axis 5 off and so nothing was to supposed to run the right motor. When i ran the program to see if the left motor worked on the left stick. Both motors ran they were not supposed to, when i took axis 2 off and tried axis 5 right y axis stick nothing happened. To run my code i save my teleop changes and Deploy it from the boot time thing at the bottom by right clicking and selecting deploy (I DO GET A MESSAGE BOX SAYING THAT CERTAIN VI's are real time vi's and that if i choose to continue all vi's on the device will close the vi's it lists are mostly camera realted though it sometimes shows the main vi as well). then i reboot and open the drivers station.
John Fogarty
Unread 22-01-2010, 11:21
Unregistered User
AKA: Kevin Forbes
So you select deploy rather than 'Run as Startup' and then reboot the cRio once it's finished downloading? When you deploy, it just loads and runs your program on the cRio while the LabVIEW program is running, and if you turn off the cRio it will lose that code. The last program set as startup will then load when you reboot. Seems like you're loading the same arcade drive program each time you turn it off and back on. Right click on Build Dependencies in the project tree and select Build, then Run as Startup once that's done. Then you should be able to reboot without losing the program.
Unread 24-01-2010, 17:56
AKA: @doctorfogarty
Talking Re: So i have another problem >.<
I'm going to feel slightly stupid if that is the problem XD thanks.
John Fogarty
Unread 22-01-2010, 11:05
hschase's Avatar
hschase hschase is offline
FRC #0342
hschase is an unknown quantity at this point
There should be usable tank drive code in the WPI Labview Library! Check it out, my programmers, who could write code with their hands tied behind their backs plan on using the library because they are pieces that they know work for the intended purpose.
Team 342 - The Burning Magnetos Team Mentor
Thanks to our Sponsors, we couldn't do it without you! Bosch, BAE Systems, SPAWAR and many others!
1 in 4 FIRST Scholarship Applicants RECEIVED Scholarships in the 2009 FRC Season..... Have you filled out your application?
another festo problem Team2883 Pneumatics 4 11-02-2009 20:22
Another IR Board Problem C222 Electrical 2 13-01-2008 17:36
Problem solved but now another question Adam Y. Programming 1 03-05-2006 08:54
Got it working now theres another problem! cdennisxlx2 Programming 11 25-03-2006 21:58
Houston, we have a problem Cauê Fundraising 0 03-03-2005 11:13
