Go to Post We were all rookies once. Some of us still are... - Wayne C. [more]
Unread 19-01-2010, 13:20
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
regulator on cylinder output?
I just need a sanity check - pretty sure this will work OK.
If we want a large force to extend an actuator, but don't need one to retract it, could we plumb 60 psi to the solenoid, 60 psi from the solenoid A port to the back of the cylinder, and then plumb 60 psi from the solenoid B port to the secondary regulator, drop down to 10-20 psi and then to the front of the cylinder? It allows us to use less air per stroke (out-in), and since the solenoid still sees 60 psi we don't have the pilot pressure limit on the downstream side of the regulator.
Close enough to taste it, too far to reach it
Pressure regulator Perci321 Pneumatics 13 24-01-2009 18:48
main regulator holty531 Pneumatics 2 10-02-2008 15:37
Voltage Regulator Robby Electrical 5 18-01-2005 07:50
12v regulator coreyjon Electrical 1 09-06-2004 22:08
pressure regulator blindguyinanorg Pneumatics 12 20-02-2004 08:54
