Go to Post Two students with no clue but enough dedication to work on something is always better than one expert who doesn't care enough not to leaveit until the last day. - Matt Krass [more]
Unread 19-01-2010, 15:10
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
Emulating a Joystick
As far as I understand, the FIRST Control System requires joysticks to use the DirectInput API. I know it would be an extremely complex task, but would anyone know how I could go about making an external microcontroller look like a joystick to the driver's station? My point being I want to be able to communicate via USB with the driver's station, sending digital and analog data, NOT going through the FirstTouch I/O board (because of data size/speed limitations). Anyone know where to start?
Unread 19-01-2010, 15:37
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: Emulating a Joystick
Actually, you are looking to emulate the HID Joystick class. DirectInput is just Microsoft's method of reading from this class.
Unread 19-01-2010, 16:02
FRC #0107
Oh! I thought DirectInput was on both sides, the firmware and the software. I've done a lot of looking at HID, but I still can't for the life of me find a good resource for learning it. Is there a better way than reading the 200 page USB documentation?
Unread 19-01-2010, 16:27
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Our team did this last year, with the blue box, because we ran out of I/O for our operator interface console (pic: http://rollingthunder.smugmug.com/20...23_SWiHf-M.jpg)
We used this Microchip board (PIC18F87J50) as a basis:
http://www.microchip.com/stellent/id...ame =en532010
We then wrote firmware for it to talk USB HID (their SDK comes with an example that acts like a mouse - we changed to act like a gamepad).
Caution, however - this little device was a pain to wire to because of the pin-out.
Here's a pic of the underside of our operator console, held by the student that put it together; the pic device is on the right in the picture:
http://rollingthunder.smugmug.com/20...50_LMRhS-M.jpg
Unread 19-01-2010, 16:43
Rookie Year: 2000
Bonus Points for Awesomeness.
Can you please post the code you wrote?
Unread 20-01-2010, 07:52
Just to clarify, the I/O board and joystick data are sent in the same packet to the robot. Meaning that while you will have additional fields, they are all read at 50Hz -- even the joystick buttons and axes.
Greg McKaskle
Unread 20-01-2010, 09:49
FRC #0107
I realize that it'll still update at 50Hz, but the reason I need to have faster updating is because I can send MORE data. If you do a parallel bitbang, the more data you have the longer it takes, to a pretty ridiculous level. Thanks for the help, I'll take a look at that. And yes, code examples would help!
Edit: I'm thinking about using V-USB... It'll take some digging around to figure out how to work it, but I think it'll do what I need fairly well.
http://www.obdev.at/products/vusb/index.html
Unread 21-01-2010, 00:46
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
I'm REALLY curious what it is that you are hooking up to. What is it that can't be wired directly to the Cypress I/O board?
Don't get me wrong... I'm not trying to discourage you from making a USB joystick emulator, cause that's a cool project, but I also want to make sure you are aware of all your options.
Cheers!
-Joe
Unread 21-01-2010, 10:03
FRC #0107
We (being a few students independently) have been designing and prototyping for a modular button box. All the modules communicate to the master module over I2C, which (in some way) communicates with the driver station. There are a few reasons why we are doing this. First of all, it is reusable. Whether we use it on a FIRST robot, an off-season robot, or anything for that matter, we control the data. So if FIRST changes something, we only need to make minimal changes to reuse the system. Also, if a module goes "bad" at a competition, we can always just pop it out and throw a new one in. We can customize HOW the data is obtained, and what from (like an SPI device, or a device with multiple analog/digital outputs, eg. blackberry trackball). We aren't limited by the number of analog/digital I/O pins that FIRST decides will be enough. Each module has 4 analog/digital inputs. There are going to be about 12 modules. Also, each module has a unique address. So if you want to rearrange the board, you don't need to reprogram.
That's the "short" version of what we're planning.
Unread 21-01-2010, 13:23
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Is the source for FIRST's default implementation of the Cypress PSoC board available anywhere? Is it against the rules to modify the default firmware on that board?
There is no reason you can't set up a simple system that uses an I2C controller and HID comms on the PSoC board. If we are not able to get our hands on the default firmware, you can check out this article for a start: http://www.cypress.com/?rID=39404
Unread 21-01-2010, 13:38
FRC #0107
Actually, it is against the rules. I had the same idea, but for some reason they want to keep it locked down. See rule <R60N>
Another question... Is there an application or something that I can use to see the output of a usb joystick? I need something for testing, and I don't have any way of telling what the joystick is actually outputting.
Unread 21-01-2010, 14:03
Maybe something like this? http://sourceforge.net/projects/usbsnoop/
Also, R60N seems kind of silly. According to the rules, I can buy or build any HID compliant USB device to hook up to the driver's station, but I cannot use the FirstTouch (which is most likely a safer/easier avenue than building any custom electronics). Why the draconian restriction?
Unread 21-01-2010, 15:58
Rookie Year: 1997
I believe you would be disappointed at the very next step if R60N didn't exist and you were to try use the Cypress board for what you are talking about. You would find out that the USB interface has nothing to do with the PSoC and that Cypress does not release the code for the processor that does. The First Touch Kit 3 board cannot implement HID (given the publicly available resources). The interface had to be implemented in a very non-generic way and the other end of this binary interface (the Driver Station software) you have no access to change. Because of this, allowing you to customize the firmware would gain rather little flexibility compared with the opportunity for frustration and failure. I don't believe the idea was simply to play Draco for the sake of it.
Unread 21-01-2010, 14:10
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
LabVIEW makes that very easy if you have HID working. Otherwise, you need something like what Tom linked.
  #15   Spotlight this post!
Unread 22-01-2010, 12:59
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
For my senior design project 2 years ago we used one of the Cypress PSoC boards to communication via USB. It was reasonably easy to setup once you figured out how their design workflow was laid out.
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
1 joystick or 2? ChrisMcK2186 Control System 18 19-01-2007 23:42
joystick ? _GP_ General Forum 1 26-02-2004 23:10
Joystick rmmlg Inventor 0 15-02-2004 16:34
No Joystick archiver 2001 2 24-06-2002 01:14
Joystick Absolute Value Technical Discussion 21 22-02-2002 10:56
