Go to Post Better is the enemy of good enough. - petek [more]
Unread 19-01-2010, 16:28
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Worm gears
I was thinking about worm gears today, for a winch application for the robot, when I remembered that there are some commonly available plastic gears, that are used in garage door openers. They work with a 1/2 HP motor, so they're reasonably strong. If you search for "chamberlain gear kit" you should be able to find them for sale from several vendors for $20-30 for the illustrated set which includes some spacers, thrust washers, and lock clips.
Unread 19-01-2010, 22:05
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Worm gears
wow, nice find! Even comes with Grease!
That'll be used for a prototype elbow in the off season.
Unread 19-01-2010, 22:10
MrForbes's Avatar
AKA: Jim
Re: Worm gears
I have a friend who installs garage doors, thus he fixes and replaces openers too. He donated a few used gears to the team, so I got to play with them. The worm gear has two teeth, spur gear has 32, for a ratio of 16:1. Apparently it's not a steep enough ratio to prevent backdriving (he said a garage door with balance spring problems will fall closed when connected to one of the openers that uses these gears).
Still, it's a nice light weight 16:1 gearset that fits 1/2" shafts, and looks relatively easy to make a box to hold the parts.
Unread 19-01-2010, 23:08
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Re: Worm gears
How does that work? Aren't worm gears only 1 tooth gears? Or does this one have two separate threads?
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 19-01-2010, 23:12
MrForbes's Avatar
AKA: Jim
Re: Worm gears
There are two separate threads.
If you study the linear actuator thing in the KOP you'll see a similar screw with more than one thread.
Very strange...but that's how it is.
Unread 19-01-2010, 23:20
Re: Worm gears
Thanks! That makes sense.
Yeah, that lead screw in the kit is just weird! I've always wondered why it has more than one thread. This year's has six, and last year's only had three (I counted ).
Unread 19-01-2010, 23:52
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Rookie Year: 2007
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
Re: Worm gears
and the year before that it was 4 threads. Odd that they change it... any Ideas of were someone could obtain a cheap gear system like this that doesn't backdrive?
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 20-01-2010, 00:00
MrForbes's Avatar
AKA: Jim
Re: Worm gears
McMaster Carr sells a hand powered worm drive winch, perhaps you could find what company makes it and see if you can get spare parts for it? just the gears?
Some circular saws us a worm drive, for example the Skill model 77. might be some adaptable parts in that?
I've been trying to think of other things....
Unread 20-01-2010, 00:14
sportzkrazzy's Avatar
sportzkrazzy sportzkrazzy is offline
AKA: Zac
FRC #1592 (Bionic tigers and 801 Horse power)
Team Role: Coach
Rookie Year: 2007
sportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant future
Send a message via AIM to sportzkrazzy
Re: Worm gears
y not use a paw and ratchet? to prevent back driving?
http://www.mcmaster.com/#gear-ratchets/=5g9esx
At the bottom.
Unread 20-01-2010, 00:19
MrForbes's Avatar
AKA: Jim
Re: Worm gears
That's what we'll probably end up doing. i doubt those stainless ones would be easy to adapt, but we might find one that is pretty easy to adapt....maybe even a part from something as simple as a ratcheting tie down strap would work? Or a socket wrench ratchet?
Unread 20-01-2010, 00:26
AKA: Zac
Team Role: Coach
Rookie Year: 2007
Re: Worm gears
thats what we have pretty much settled on. lol. Ur going to here a loud clanking noise we we go up but only for about 2 seconds if that lol.
Unread 20-01-2010, 01:55
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Re: Worm gears
If there were an FRC award for posting the most useful ideas, images and videos on Chief Delphi over the past three years, Jim, your team would have to be at the top of my list of nominees.
This is another great piece of info.
Jason
P.S. Those gears must be tough... one of my garage doors had been a bit sticky lately when it was coming down and when I checked it out, it turned out that the spring on one side had come disconnected when a fastener failed. It must have made a bang when it went, but the opener just kept chuffing right along. A quick fastener replacement (er... "UPGRADE PART" to use FRC speak) and some retensioning and it was as good as new... never missed a beat.
Unread 20-01-2010, 03:09
MrForbes's Avatar
AKA: Jim
Re: Worm gears
Thanks, Jason! We try to help where we can....
I've also learned that posting our crazy ideas here is a great way to find out quickly if we're headed in the wrong direction.
Unread 20-01-2010, 07:57
Edoc'sil's Avatar
FRC #2531
Rookie Year: 2007
Re: Worm gears
ya, I saw that there was a worm gear in a circ saw, ill see what i can do about finding a broken one and post its ratios and stuff.
  #15   Spotlight this post!
Unread 20-01-2010, 08:14
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
Re: Worm gears
Nice find. I had more or less ruled out a worm gear since they generally are extremely low efficiency (relative to a spur gear and ratchet) in order to prevent backdriving, but using a higher efficiency worm drive with a ratchet might be an option. Any idea of the efficiency of this set?
Close enough to taste it, too far to reach it
Question about worm gears kajeevan General Forum 10 20-08-2008 20:39
Worm Gears chooKcha Technical Discussion 4 30-06-2007 18:12
Worm Gears FIRST JerseyKid Technical Discussion 13 18-01-2006 10:13
Looking for nylon worm gears (~64 pitch) Travis Covington Technical Discussion 3 12-03-2004 22:30
