Go to Post "The reason we struggle with insecurity is because we compare our behind-the-scenes with everyone else's highlight reel." - davidthefat [more]
Unread 19-01-2010, 21:54
xSpongeX xSpongeX is offline
FRC #3369
xSpongeX can only hope to improve
Joystick Controls of Axis Camera
I added the Joystick code from the joystick input example in the servo camera example to control the servo camera via the joystick.
But, the example has 2 front panel controls which I am replacing with the output s of the "Get Joystick Axis" SubVI's.
How do I scale the output values from 0 to 170?
Thanks
Unread 19-01-2010, 23:05
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Joystick Controls of Axis Camera
Use math functions. To turn a value between -1 and +1 to a value between 0 and 170, add one then multiply by 85.
joystick axis in labview frcchile NI LabVIEW 7 20-02-2009 12:06
Axis 3 on joystick camper365 Programming 3 13-02-2009 22:49
Tri-axis Analog Joystick KVermilion Control System 5 19-01-2005 00:24
Inverting Y axis on joystick FormatteD_C Programming 7 24-02-2004 16:56
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
