Go to Post If you want to make change, you have to know what you're trying to change. - [more]
Unread 20-01-2010, 00:41
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Victor/Jag Testing set up
Here is an easy way to test those victors and jags.
A simple servo tester wired to a victor, no need for a CRio. Quick and painless, hope this help you guys.
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 20-01-2010, 04:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Victor/Jag Testing set up
Please tell me there's a fuse in there somewhere that I'm not seeing.
Unread 20-01-2010, 09:36
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Rookie Year: 1999
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
And that you're not running these without the fan running? That is an easy way to burn them out!
Unread 20-01-2010, 10:15
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
I understand your worries, but the motor is free spinning. We would never run it like that on a transmission or under any load. As for the fan thing, we used these countless times in underwater robotics application with amp draws pretty low, like 15 amps for a second (Like a free spinning motor).
Team 842 Programmer
Pictures at:
Videos -
pic: cRIO CAN Jag Andrew Schuetze Extra Discussion 63 25-07-2009 01:48
Failed attempt to explain JAG linearity vamfun Technical Discussion 66 05-06-2009 13:13
2009 Camera and Jag inventor models problem Creator Mat CAD 5 08-03-2009 14:05
1 Jag and 1 Victor not responding correctly. elbuo NI LabVIEW 4 17-02-2009 22:57
Victor::Set not working wireties C/C++ 7 28-01-2009 04:53
