Go to Post I understand that I'm in the minority when it comes to these things, so when the coverage switches to one these stories I exercise my right to change the channel. - Karthik [more]
Unread 01-20-2010, 12:59 AM
gwlund gwlund is offline
FRC #2605
gwlund is an unknown quantity at this point
Robot code simulation on Windows box with Windriver
I was wondering if anyone had advice on the best way to develop, build, and run a program locally on a computer without downloading the program to the cRIO. Obviously the WPILibs are not setup to work without the supporting hardware resources but I wanted to setup a simulation environment so concurrent development can happen on the project. I can easily override the WPILib classes to put a debug shim layer class in between the libs and our custom code.
Windriver has a VxWorks simulator that appears to be missing from the FIRST build. Another option would be to compile for a native build using gnu toolchain.
Wanted to know if there was some knowledge out there before I plowed my own road.
Windriver 2010 Installation Windows SDK function Error Captain Fink C/C++ 1 06-01-2010 01:52 PM
Cruch Time Help! 3 LabVIEW Tutorial Videos: State Machines; Faster Code; Simulation LVMastery NI LabVIEW 11 02-09-2009 02:36 PM
Building WindRiver Code? lingomaniac88 Programming 4 01-28-2009 05:09 PM
Problem debugging code with WindRiver LinuxMercedes Programming 3 01-07-2009 11:10 AM
Open Simulation with Dashboard Provider running Ray Gitchell LabView and Data Acquisition 8 02-02-2007 12:21 PM
