Go to Post Trust your data! - eugenebrooks [more]
Unread 20-01-2010, 04:02
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
adjustable pressure regulator
We're planning to have maybe three kicking distances using pnuematic pistons and a level kicker. We would like to vary the kick power using a adjustable pressure regulator.
The plan would be to set the master regulator to 60psi and the downstream regulator would be for adjustment for the kicker. Has anyone done this before? I was thinking to get another regulator and attach it to one of those window motors with an encoder to monitor the position of the knob. However this seems way to complicated. I would like to find a simpler way.
Thanks for your time!
Unread 20-01-2010, 07:48
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: adjustable pressure regulator
windell,
That is exactly how teams have adjusted downstream pressure in the past. It is not a great way to do it but it does work. You might want to investigate using multiple actuators that have different actions instead.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 20-01-2010, 08:08
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
Or multiple regulators and solenoid valves
Unread 20-01-2010, 08:31
Craig's Avatar
Craig Craig is offline
Drive it like YOU BUILT IT!
FRC #4976 (REBELS!)
Craig is an unknown quantity at this point
one option is to use a quick exhasut valve for fast release
calibrate the system to exhasut through the solenoid valve for a short kick, then have a second loop which can exhaust through a quck exhaust valve releasing air faster for a longer shot.
similar function could be achieved with flow controls on the exhaust side of the valves, have 2 loops set at different rates.
Founding member: Team #4976 GO REBELS!
Spent some great years with #2386
Founding Member: Team #843
Unread 21-01-2010, 01:31
elmer_fud elmer_fud is offline
mentor/code monkey
FRC #2859
elmer_fud is an unknown quantity at this point
I was also thinking you could do this with 2 valves with differn't sized orifices. If you did it right you would be able to get 3 differn't air flows resulting in 3 kicking forces.
doing it this way would result in 2 differn't air flows. If you open both valves at the same time you could get a third air flow. The differn't air flows will result in differn't kicking speeds.
Unread 21-01-2010, 01:42
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
What about having 3 solenoids all tee'd into the cylinder? Open one for short, 2 for medium, and 3 for fast. Or, have one or more be on a regulator set lower than 60 PSI and open that one (or more) for the short-range shots.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 21-01-2010, 16:27
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
Team Role: Coach
Rookie Year: 2000
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Where is the link to the "free" pneumatic cyliders? I followed the link " Where to get more " on related documents
2 Bimba Manufacturing Bimba Cylinders - custom order
clicked www.bimba.com
and it took me to
ATTENTION FIRST TEAMS!
Due to the enthusiastic, yet overwhelming number of requests from FIRST teams, igusŪ has altered its policy regarding additional product donations. If you would like to use igusŪ products not included in the kit of parts, we cannot donate them free of charge. However, there are plenty of great igusŪ components in your FIRST tote - so check 'em out!
Am I lost?
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 21-01-2010, 18:44
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
This link looks like an order form:
http://www.bimba.com/FirstFree.aspx
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 21-01-2010, 23:22
joeweber's Avatar
Coach team 1322
Team Role: Coach
Rookie Year: 2000
Thank's , I looked all over for it but I must have missed one place.
Unread 22-01-2010, 06:55
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
Note tha while a quick exhaust valve is a very useful pneumatic part, it's use is not specifically permitted by <R72> and therefore PROHIBITED by <R71>
Former Mentor Team 1771
Former mentor Team 4509
Unread 22-01-2010, 09:07
joeweber's Avatar
Coach team 1322
Team Role: Coach
Rookie Year: 2000
We are using a 2 in cyinder, it has a larger fittng hole so we installed a "T" and connected two valves. Two will allow for faster release and using just one will slow it down. You could add a thrid in line with the second with the pressure further reduced for close shots.
Unread 22-01-2010, 00:30
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
http://www.omega.com/ppt/pptsc.asp?ref=ip610&Nav=prel01
Check out the IP610-60. I believe it should be relatively simple to integrate and very precise (especially compared to physically turning a pressure regulator!) if you have someone comfortable with programming and the control system.
I've not seen one of these in use before, but as far as I can tell in a quick rules check, they ARE legal pneumatic components AND legal electrical components for the 2010 FRC competition.
Hope this helps.
Good luck!
www.metalmoose.com
Unread 22-01-2010, 09:15
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
I might recommend one of the Voltage to pressure models: http://www.omega.com/ppt/pptsc.asp?r...211&Nav=prel01
The one you linked to is controlled by current, which is ever so slightly more complicated (but still not hard to do).
I have NOT verified if these would be considered legal, but Q&A it if you are unsure.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2016)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 22-01-2010, 18:24
mentor/code monkey
FRC #2859
I thought there was a $300 COS electronics part limit
edit: <R22> No individual item shall have a value of over $400.00. You could use the first valve linked I think
  #15   Spotlight this post!
Unread 22-01-2010, 18:29
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
You're thinking of the rules from some years ago. There hasn't been a separate electronics limit for quite some time. $400 is the only limit other than the grand total.
Past teams:
Pressure regulator Perci321 Pneumatics 13 24-01-2009 18:48
Does the Norgren Pressure Regulator show working pressure or stored pressure? Madison Pneumatics 7 14-02-2008 17:40
Nason Pressure Regulator Calvin_1631 Pneumatics 9 09-02-2006 00:40
Nason pressure regulator...HELP!!! Bob Steele General Forum 0 25-02-2004 16:08
pressure regulator blindguyinanorg Pneumatics 12 20-02-2004 08:54
