Go to Post FIRST - Breaking stereotypes everywhere - Sparks333 [more]
Unread 01-20-2010, 10:54 AM
frenchie4111 frenchie4111 is offline
None #1111
frenchie4111 is an unknown quantity at this point
Running Code in Debug Mode | Power Hawks 1111
Hey Frenchie Here from team 1111,
We are just starting to jump into the world of C++ on the cRIO and have heard about a code debugging mode where it does not actually burn to the cRIO but saves in ram? We have looked through documents and have not found a way to do this. Help please.
Thanks
Unread 01-20-2010, 02:26 PM
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Re: Running Code in Debug Mode | Power Hawks 1111
First you must undeploy any code set for startup using the First menu. Then right click on the project after you have built it and select "Execute Kernal Process" or "Debug Kernal Process". Its on page 11 of the file "GettingStartedWithC.pdf" from WPI
From the document:
To start a debug session first make sure that the PC is connected to the target. Right-click on the project name in the “Project Explorer” window and select “Debug Kernel Task…” The Debug dialog is displayed.
Figure 1: Setting the entry point on a Debug Configuration for a robot program.
Change the name of the debug target to something meaningful like “2010TargetTest” shown in the example. Select as the entry point the function FRC_UserProgram_StartupLibraryInit. On the debug options tab, select “Break on Entry” and “Automatically attach spawned Kernel Tasks”. This tells the debugger to stop at the first instruction, and to make the spawned task (your robot task) available to debug.
Brian
Brian K
Team 1225 Robotics Mentor
Unread 01-20-2010, 05:18 PM
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
its Run Kernel Task and Debug Kernel task not Execute Kernal Process and Debug Kernal Process
they have a green play icon with a gear in the corner and bug icon with a gear in the corner (respectively)
I would normally use Run Kernel Task instead of Debug Kernel Task
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 01-20-2010, 07:37 PM
None #1111
Ok, i have downloaded the .pdf and on the very first set up (The Debug Settings window) it says "Connection to use: " and our drop down menu is empty, although the direstions seem to assume that there is already an entry there.
Thanks guys for helping the noobs out
Unread 01-20-2010, 07:42 PM
byteit101's Avatar
http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf page 4-6
Watchdog.Kill();
Unread 01-20-2010, 08:10 PM
None #1111
Originally Posted by byteit101 View Post
It worked byteit thanks a bunch, this si the second time you have helped us.
[url="http://mylifeisnerdy.co.cc"]My Life Is NerdyURL]
Unread 01-20-2010, 08:27 PM
byteit101's Avatar
You're welcome. If you want to, you can add to my reputation with the little scale on the orange bar above this post
Watchdog.Kill();
cRIO Not Running Code?!? JohnFogarty Programming 11 01-17-2010 07:08 PM
Running camera code wirelessly windell747 NI LabVIEW 4 02-09-2009 09:27 PM
code example to set 4x encoder decoding mode mode fdelagarza C/C++ 1 02-02-2009 05:14 PM
Problem running compiled code jskene Programming 10 01-23-2005 09:13 PM
auton mode running motors incorrectly BK36 Programming 2 03-12-2003 02:43 AM
