Deploy doesn't work
Our control system has been working fine for a while. However, today, I made some small changes to the code, built it, and deployed it through the Classmate. This has always worked before. However, when I went into Driver mode, the Driver Station said there was no code. I rebuilt and redeployed the code, and it still didn't work. I also tried building and deploying the default code, with no luck. Any ideas what to do?
Re: Deploy doesn't work
What do you mean by "went into driver mode"?
If you're deploying the code using the Classmate, logging off the Developer account stops all running programs. Unless you told the cRIO to run the code at startup and rebooted it, the code will not be running. The proper thing to do is run the Driver Station program while still logged on as Developer. |
| RSL Doesn't work | BKmike | FRC Control System | 4 | 02-16-2009 12:01 PM |
| Run works but build&deploy doesn't | program1 | NI LabVIEW | 3 | 02-03-2009 10:32 PM |
| LCD Doesn't work :( | magical hands | Programming | 6 | 03-08-2007 08:37 PM |
| sensor doesn't work | PBoss | Programming | 7 | 01-29-2003 06:39 PM |
