The Shooter (and Kicker) Saftey Thread
Now that teams have decided on their general strategies and are starting to prototype/design it's probably time to discuss how to make a safe mechanism.
My comments are based on my experiences while a member of team 1726 and are intended to spark a discussion of safe practices. I would also deeply appreciate comments on safety from the numerous professions on this forum. Note you may be able to make a safe robot while violating some of the below comments there is always some room for discretionary judgments Also in the below stored energy does not refer to energy stored in the battery or in pneumatic tanks. It refers to energy stored in latched pneumatic cylinders/springs/other elastic deformations/flywheels etc. General Comments: --Efficient systems are often safe systems. Using the minimum energy required to complete a task requires less stored energy and produces less thermal energy (smoking motors). --Be sure to consider how your shooter/kicker performs if it fires without a soccer ball. In this case the energy normally transferred to the soccer ball will need to be dissipated elsewhere. --Both mechanical and software based fail safes are prone to failure. Be sure to consider what will happen when your robot is turned off. --Consider how your system will perform after being fire 100 times or even 1000 times? Set clear criteria for when parts should be replaced. Regarding Stored Energy Systems: --Mechanisms which store energy in pneumatic cylinders, elastic deformations, and fly wheels tend to be more dangerous than systems which do not. If you can kick the ball without storing energy, kudos to you. --Systems should be charged/compressed/rotating only when necessary. Robots should not have to drive around the field with "loaded" systems for the entire match. I prefer systems which charge and release in one fluid motion (for example using off center circles). --If a stored energy system is not in use the energy should bleed off rather quickly. You don't want to end a match with springs/cylinders compressed. --Warning systems are wonderful. Lights/danger signs which appear when your robot is storing energy should be a priority. Make sure your systems is clear to everyone. Regarding Latches: --I tend to be afraid of systems which use latches to hold back pistons or springs. Using a latch invites accidental releases. --If using a latch use one designed to handle what ever load your mechanism will place on it. I've notice many teams using fence latches to hold back ~300lb loads: this is unsafe. Look into industrial quick releases designed to hold load. Be very careful when modifying latches (something which teams are also prone to do) this could have unexpected consequences later. --Consider carefully the default state of your latches. Could a referee touching your robot at the end of the match cause the kicker to fire? --What kind of warning system to do you have when the latch is engaged? How do other teams know? --Do you have procedure or backup if the latch become jammed? Well that's all that I can think of right now. Remember be safe and have fun! Last edited by Matt H. : 20-01-2010 at 15:07. Reason: formatting |
| Rookie Team 3357 The COMETS Kicker Prototype | GGCO | Robot Showcase | 21 | 19-01-2010 23:06 |
| Team 399's Chassis and Kicker Tests | Jeremy Germita | Robot Showcase | 10 | 18-01-2010 23:48 |
| Saftey Glasses | Southgate Servo | General Forum | 19 | 24-03-2008 22:10 |
| pic: Dean and Woodie Signed Saftey Glass | andrew348 | Extra Discussion | 8 | 27-03-2007 16:36 |
| pic: Team 1501's shooter...errr kicker | Wayne Doenges | Robot Showcase | 9 | 14-02-2006 14:44 |
