Go to Post C'mon you guys you're all inventors. You guys should be making a portable cryogenic sleep chambers for those long bus trips! You got two weeks before you have to go. Get cracking! - Koko Ed [more]
Unread 01-20-2010, 04:40 PM
UverSekai UverSekai is offline
FRC #2872 (CyberCats)
Rookie Year: 2010
UverSekai is an unknown quantity at this point
Net Beans Deploying the Java Code
We re-imaged our CRIO to the Java technology, built and ran the program, however when the output, after running the main program to transfer it to the CRIO begins, the deploying at Setting Up for Run. What is the problem and what can we do to insure that our code transfers to the robot?
Unread 01-20-2010, 05:09 PM
FRC4ME FRC4ME is offline
FRC #0339
Rookie Year: 2007
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Re: Net Beans Deploying the Java Code
The way my team fixed this problem is by giving the development PC a static IP address.
I don't think that's supposed to be an issue, but for us, it made a difference for some reason.
Go directly to queue. Do not pass pit.
Unread 01-20-2010, 05:15 PM
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
http://www.usfirst.org/uploadedFiles...ed-Rev-0.7.pdf
See the bottom of page 31. You should have a static IP of 10.xx.yy.6 where xxyy is your team number on your development computer. (10.xx.yy.5 on the classmate)
Deploying code from the 2010 driver station - Netbeans joshholat Control System 5 01-23-2010 03:01 PM
Issue deploying Code rudun Java 5 01-18-2010 09:24 PM
Code to communicate with the net book [JAVA] Sean Raia Programming 0 01-17-2010 03:43 PM
Net Beans Error Help please fallenangel529 Java 1 01-16-2010 07:31 PM
Having trouble with Deploying code Hatefulhippo Programming 2 02-15-2009 02:02 PM
