Go to Post Turning is overrated - Allison [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 20-01-2010, 16:48
Abole Abole is offline
FRC #3284
Abole is an unknown quantity at this point
Inventor 2010 Parts Kit complications
I have downloaded the the 2010 FRC parts for inventor and when i try to open some of the files, for example the andy mark Chasis, it doesn't bring in all the parts or doesn't open it at all. Just wondering if others were having the same problem and would be a big help! Thanks
Unread 20-01-2010, 16:55
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Inventor 2010 Parts Kit complications
I had no problem opening the 2010 KoP chassis from AndyMark.
Its hard to tell what your exact problem is, but one thing is you need to remember to keep all of the individual part files in that same "active project" folder as the assembly. If not, Inventor will have a hard time locating all the parts of the assembly, and might open with missing parts.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 20-01-2010, 17:00
FRC #3284
Yeah, im just a rookie really with inventor and we're a new team this year, but i'm trying to think of other ways to describe the problem. I think there might have been a problem with the content center library and we tryed updating it which it did add some bolts to the overall image but still couldn't load some things on the image.
Unread 20-01-2010, 18:05
wrenauld's Avatar
wrenauld wrenauld is offline
FRC #1922 (OzRam)
Team Role: Coach
wrenauld is an unknown quantity at this point
Your source for the KOP parts will make a difference with what you can do with the part files. If you got them from Andymark the are standard part files. If you got them from Autodesk most are part files that a relatively new feature called base solids. Basically this limits editing of standard parts. Example: Frame rails can only have their length change by moving a face while in the solid editor. I have not played with it much but this is what I found so far. I can see this being used in industry but is a little cumbersome for our team at this point. Hope this helps.
W.R. team 1922 OzRam
Unread 20-01-2010, 19:43
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
Team Role: Mechanical
joek is an unknown quantity at this point
it's because parts were placed from the content center
and on a side not: the chassis was assembled wrong
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 22-01-2010, 19:55
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Hi all,
I have had a couple of comments on the chassis. The intial posting on the autodesk.com\first site matched the original design prior to kick off. A design change has since been implemented. I have uploaded a new assembly file to match the assembly design change.
Any questions on this, please contact phil.dollan@autodesk.com
Unread 28-01-2010, 17:38
FRC #3284
We've recently downloaded an update on content center after we had already downloaded the parts for inventor. It has brought in some new parts when i try briniging up some pieces, but hardly any though, maybe like 12 bolts on the chaisis.
**FIRST EMAIL**/2010 FRC Modeled Kit of Parts Now Available! Autodesk Inventor Profe Mark McLeod FIRST E-Mail Blast Archive 0 12-01-2010 10:32
Inventor model for Kit of Parts Transmission q_prof Inventor 2 12-02-2006 23:54
Inventor drawings of parts from kit patrickrd Inventor 1 11-01-2002 14:16
Inventor and Virtual Kit of Parts Torchin Inventor 1 09-01-2002 09:59
