Go to Post Why is it whenever you tell someone there is a million billion stars in the universe they believe you, but if you tell someone that the bench over yonder has wet paint, or if usfirst.org comes up as the 1st result in Google people have to try it for themselves? - artdutra04 [more]
Unread 20-01-2010, 16:56
specs101kid specs101kid is offline
FRC #1529 (Cybercards)
specs101kid is on a distinguished road
cRio error
We were trying to image our cRio and came up with this error. What should we do
Unread 20-01-2010, 17:03
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: cRio error
1. run the Labview update program to get the v19 image
2. check Format controller and select the v19 image
3. put in your team number (I HIGHLY doubt you are team 254128)
4. Check the always run deployed code at startup box under labview
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 20-01-2010, 17:12
Re: cRio error
Where do you find the v19 image? Thanks for your help. =)
Unread 20-01-2010, 17:20
byteit101's Avatar
Re: cRio error
in the Labview update http://joule.ni.com/nidu/cds/view/p/lang/en/id/1534
Watchdog.Kill();
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Re: cRio error
And your IP address setup (for your computer and/or the Classmate, the wireless router, the wireless bridge on your robot, and eventually the cRIO) should be 10.15.29.*, where * varies per the device. The 15.29 comes from your team number 1529.
Please see the Section 2 "Getting Started" manual available at http://usfirst.org/roboticsprograms/....aspx?id=10934
Once the IP address is set on your computer, you won't be able to access the internet with it. You'll have to chage its IP address setup back to its 'automatic' setting to do so. Again, see the doc.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 20-01-2010, 17:31
Talking Re: cRio error
thank you for all of your help. We did do the update the other day but it did not change anything so we will update again. once again, thank you for all of your information!
Unread 20-01-2010, 17:34
byteit101's Avatar
Re: cRio error
if it doesn't fix your problem, uninstall and reinstall the Labview update
Watchdog.Kill();
MPLAB error: Error [1027] unable to locate 'serial_ports.h' rokenboker Programming 10 03-09-2009 16:29
v11 cRIO Image Error Team1710 Programming 7 14-02-2009 12:56
CRIO Error 60 seanl FRC Control System 14 18-01-2009 16:29
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
