Go to Post Spelling mistakes make me sad...Almost as sad as not being able to go to Atlanta this year.. Almost. - Elgin Clock [more]
Unread 20-01-2010, 18:31
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
classmate configration
I read the GETTING STARTED
TABLE OF CONTENTS , Section 2
Set team number is OK.
I try to configure the classmate by to my PC I fail.
If this is not the classmate PC you should set the
© FIRST 2010 FRC Control System Manual: Section 1 – Introduction, Rev1 Page 32 of 58
address to 10.xx.yy.6 as the Driver Station defaults to 10.xx.yy.5 for its IP address. In this
text box, change the final digit .5 to .6..
My question is it the same config. As the last year
Component Default IP
(Team 0) Team Config
Wireless Bridge (on Robot) - 10.xx.yy.1
CRIO, port #1 10.0.0.2 10.xx.yy.2
CRIO, port #2 Not enabled 192.168.0.3
DS Wireless - 10.xx.yy.4
DS/ classmate 10.0.0.5 10.xx.yy.5
PC - 10.xx.yy.6
Camera 192.168.0.90 No change
Please if any one can help
TEAM 1946-Tamra
Unread 20-01-2010, 19:26
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: classmate configration
The Classmate needs to have the IP address of 10.xx.yy.5, where xx and yy are the 4 digits of your team number. The cRio will have an IP address of 10.xx.yy.2 when imaged with the FRC cRio Image Tool. If you set your team number in the correct box on the Driver's Station, it will set the Classmate's IP to the correct number automatically. To get it working wirelessly, read section 2.10 of the control system manual. Hope this helps.
I'm right 90% of the time, so why worry about the other 3%?
Unread 22-01-2010, 17:32
yara92's Avatar
AKA: Mohamed
thank you for reply
it help us, but still we have problem there is no respond ping the cRio, one times he respond then did, all the time not responding
TEAM 1946-Tamra
Unread 22-01-2010, 17:50
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Rookie Year: 2000
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Mohammed,
Have you re-imaged the cRio with the crossover cable?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 23-01-2010, 00:53
Green2 Green2 is offline
FRC #2338
Green2 is an unknown quantity at this point
To have reliable communication with the cRIO (either through tether or wireless bridge), it is best to disable the wireless communication on the classmate PC (that is unless you are using a wireless connection to the game router, in which case make sure you are not using the wired Ethernet connection also).
And you have to disable the windows firewall.
If you are still unable to communicate to the cRIO, then try re-imaging using a tether.
Double check your computer IP setting.
If it still doesn't work, here is a link to the NI website with some additional advanced troubleshooting methods.
http://decibel.ni.com/content/commun...ssions&start=0
Good luck!
Barry
Unread 23-01-2010, 08:04
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
I don't think that's necessary.
Unread 24-01-2010, 10:33
FRC #2338
That was what we thought...but we had no communication until we disabled wireless (even though we can ping the wireless bridge and the cRIO over wireless with the firewall on).
Barry
Unread 24-01-2010, 15:59
FRC #2230
Barry
Wireless is not the same as a firewall.
Unread 25-01-2010, 13:58
FRC #2338
Sorry, what I meant was both wireless and firewall needed to be disabled in order for us to get wireless communication to the wireless bridge.
Barry
Unread 24-01-2010, 01:24
yara92's Avatar
AKA: Mohamed
thanks
we downlowd the latest Driver. it works perfect.
TEAM 1946-Tamra
Unread 24-01-2010, 07:48
In my experience, the formatting of the cRIO is the finicky portion of the setup that is thwarted by other NICs and firewalls. Normal operation, downloading programs and such works fine. I suspect most of the tools will cause a dialog asking if you want to allow them to connect to the cRIO, and if you allow, the exception will be created.
If this is not the case, it would be nice to know the details.
Greg McKaskle
Classmate PC lon.bushweiler Control System 8 22-01-2010 14:46
Classmate Issues ROFLcopter NI LabVIEW 10 16-01-2010 21:56
Classmate HELP!! mcristina444 FRC Control System 12 15-01-2010 18:59
Classmate MachineSMMC NI LabVIEW 10 15-01-2010 13:47
classmate help!!! a kenny03 General Forum 1 13-01-2010 20:33
