Go to Post Define "surgery". I think we have enough close calls with "surgery" as it is. Thank god for disable dongles. - geeknerd99 [more]
Unread 20-01-2010, 21:26
Gorjessie Gorjessie is offline
FRC #0368
Gorjessie is an unknown quantity at this point
Field Materials
Does anyone know what kind of tape they use for the center line of the field?
Is it some sort of reflective tape or regular duct tape?
Thx.
Unread 20-01-2010, 21:29
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Field Materials
Thx.
99% sure it's gaffer's tape. That's what's used for the rest of the field, too. No, it won't be reflective if it's gaffer's tape. Just a nice shiny white color.
I've set up fields since 2007, and I haven't seen hide or hair of duct tape in any of those years--it's all gaffer's tape.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 24-01-2010, 00:11
IceStorm IceStorm is offline
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
Re: Field Materials
By chance are you trying to come up with ways of detecting the white line? If so i would be interested to know what you have tried so far. were looking to do the same thing.
Unread 24-01-2010, 04:23
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: Field Materials
There was an optical sensor included in the kit in 2003 and 2004 (I believe made by Banner). You had to be directly over the line though, which wouldn't do you any good this year since you can't cross over during auton.
2001-2004: Team 100
2006-Present: Team 254
Unread 24-01-2010, 06:38
mcf747 mcf747 is offline
AKA: Matthew Forman
FRC #0190 (Team 190)
mcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud of
Re: Field Materials
I don't have my rule book handy and honestly don't want to go digging though PDF's right now either. But is it contact with the line or going completely over it with the robot. That draws the penalty? If its the latter then the opto sensory might still work.
Have you thought about sing the current KOP camera for line detection only. You could have it pointed out at a determine angel and then use the vision tool to say something along the lines of "when line enters lower half of frame stop or turn or do whatever you want to do with the robot" this would give the robot enough time to react and may make programming a bit easier.
Matthew
Unread 24-01-2010, 09:35
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
Rookie Year: 2007
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Re: Field Materials
As our team interprets the rule, it's going over the line completely that incurs a penalty. But you might want to ask the FIRST Q&A, if you want a definite answer.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 24-01-2010, 09:41
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: Field Materials
You cant completely cross over so long as part of your robot is still in your zone you are ok and penalty free
Unread 24-01-2010, 09:43
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Field Materials
Already asked and answered on the Q&A
http://forums.usfirst.org/showthread.php?t=13841
Under Rule <G30>, the ROBOT would receive a PENALTY when it "completely" crosses the CENTER LINE. Thus, the PENALTY is assessed when when all parts of the ROBOT (i.e. the vertical projection of the entire ROBOT) cross the line.
Unread 24-01-2010, 10:36
AKA: Chad
Re: Field Materials
Does anyone know what model that sensor might have been. Not sure where to find a KOP list from 03 or 04 as this is our teams 3rd season only.
Unread 24-01-2010, 12:28
Cory's Avatar
AKA: Cory McBride
Re: Field Materials
Do you trust an autonomously controlled robot to not go over that line, while straddling it?
I don't.
2001-2004: Team 100
Unread 24-01-2010, 12:30
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
Re: Field Materials
I don't.
I trust my robot, now if i could just trust my programmers lol
Unread 24-01-2010, 15:01
synth3tk's Avatar
AKA: David Thomas
Rookie Year: 2007
Re: Field Materials
Your programmers should always be trusted. Usually those pesky "bugs" are errors in the computer reading the code incorrectly, not the humans typing it wrong.
[FTC]: Full Field vs Low-cost Field 595294001 FIRST Tech Challenge 13 04-05-2011 19:10
Field Materials?? Cyberphil Technical Discussion 10 27-01-2010 23:42
Field Corner Dimensions Missing from Field Drawings? Don Wright General Forum 2 13-01-2009 19:57
Materials Jeff K. General Forum 11 22-01-2005 02:24
Materials Finch Rules/Strategy 2 28-01-2002 23:00
