Go to Post How the mentors of a team inspire their team is unimportant, as long as the team is inspired to do great things. We on 1824 believe in 'student designed, student built', but that does not mean that all teams should do as we do. For inspiration comes in many forms. - Daniel_LaFleur [more]
Unread 20-01-2010, 22:25
caincteam2777 caincteam2777 is offline
FRC #2777
caincteam2777 has a spectacular aura aboutcaincteam2777 has a spectacular aura about
new festo valves
anyone know how to hook up the new festo valves with electrical and pneumatics. cant seems to find it.
also it says 24v, will it work on 12v?
FRC #2777
Re: new festo valves
im looking for the pdf drawing and instructions for the old and new festo's. you the D shape one and the new longer rectangle one
Unread 20-01-2010, 22:44
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The 2-port side of the Festo get fittings and are then tubed to either end of the cylinder.
On the 3-port side only the middle port gets a fitting and that's the air-in port from your 60psi regulator.
Each end gets a wire connector and each side gets wired back to pins on the Solenoid bumper (cannot be wired to a Spike relay). You can take the 2-pin connector cables that came in the KOP, cut them in half and use an end for each side of the solenoid.
It needs 24v so the Solenoid bumper must have it's power wired to the Power Distribution Panel's two open 24v connections (for the cRIO power).
Search the Festo site for VUVG-L10-B52-T-M7-1P3
Quick Summary
Documentation
Datasheet
Here's what it looks like with the ports on and wiring.
The blue dots on the top are for manual operation. Push them for a momentary test or push & twist them with a screwdriver to stay on. Make sure you have a working pressure of 1.5-8 bar. Okay, okay it needs at least 22 psi to operate.
Unread 21-01-2010, 01:59
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
Im sorry for not understanding this but does this mean that we don't connect the pneumatic solenoid to a 20 amp fuse on the power distribution board?
Unread 21-01-2010, 03:38
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
Correct. You supply 24 V to the Solenoid Breakout Board as per:
<R45> All electric power utilized by the ROBOT shall be distributed from the load terminals of the Power Distribution Board. Circuits may not bypass the Power Distribution Board to connect directly to the 120-amp loop.
A. The cRIO-FRC power input must be connected to the 24 Vdc supply terminals on the Power Distribution Board. With the exception of one Solenoid Breakout Board, no other electrical load can be connected to these terminals.
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 21-01-2010, 06:38
jsasaki's Avatar
AKA: Jun Sasaki
Thanks a lot Ted
Unread 21-01-2010, 08:23
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
go here: http://usfirst.org/roboticsprograms/....aspx?id=10934
and look at robot power distribution diagrams.
there are 12 and 24 vdc variants
Ed Barker
Unread 22-01-2010, 22:36
FRC #2777
is there wiring diagrams for both festos?
Unread 23-01-2010, 00:43
Just Itinerant
Be careful, the 2009 Festo is 12v and not compatable with the 2010 Festo which is 24v.
By "other" Festo I assume you mean the 2009 KOP Festo?
That is NOT legal for use on the robot this year, because it is commercially available.
2009 Festo Wiring
The 2 wires then go back to a 12v Solenoid Bumper or a Spike (Spike is then controlled by a PWM cable connected to a Digital Sidecar Relay.
The 2010 Festo wiring is just plug in the wired connectors that came with it, then the red and black wires go to a 24v Solenoid Bumper.
Last edited by Mark McLeod : 23-01-2010 at 21:21. Reason: Thanks Andrew for the reminder
Unread 23-01-2010, 02:38
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
Team Role: Coach
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
So are you still allowed to use the 2009 festos?
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 23-01-2010, 08:10
Just Itinerant
Thanks for the reminder, I neglected to address that point.
The 2009 and earlier KOP Festo solenoid is NOT legal for use on the robot this year.
They are commercially available (thanks Corey).
Unread 23-01-2010, 05:44
jsasaki's Avatar
AKA: Jun Sasaki
2009 Festo Wiring
Im sorry but im not exactly getting this but from what i've been hearing/reading the pneumatic bumper is connected to the 24v source on the distribution board (2 left over leads on the WAGO connector that connects the cRio to the Distribution board) and then the two ends of the solenoid being connected to the bumper right? So if this is right that means were gonna have to use 2010 and only the 2010 festo valves hence the 2008 and 2009 SMC and Festo valves are not going to have the right amount of voltage thus not working right???? This years pneumatics are complicated we should have sticked with the old SMC and Festo solenoid
thanks for you help
Unread 23-01-2010, 05:48
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
thanks for you help
That is correct, you could only power the 2010 Kit solenoid valve off of the 24V Solenoid Breakout (or any purchased 24V solenoid valves that meets the requirements of the rules).
You can use an additional Solenoid Breakout board connected to a 20A breaker to power 12V solenoids on the same robot. You could also use one or more Spike Relays to power 12V solenoids.
Unread 23-01-2010, 19:10
smevawala smevawala is offline
FRC #1257
smevawala is an unknown quantity at this point
That is NOT legal for use on the robot this year, because it must be commercially available (find someplace selling them-eBay doesn't count). Those were a special FIRST only edition.
2009 Festo Wiring
Um R33, from my knowledge, says that the 2009 Festo valve is legal.
Originally Posted by FRC Manual
<R33> COTS items from ROBOTS entered in previous FIRST competitions or COTS items that are
no longer commercially available may be used under the following conditions:
A. The item must be functionally equivalent to the original condition as delivered from the
VENDOR (e.g. a part that has non-functional label markings added would be permitted,
but a part that has device-specific mounting holes added would be prohibited), and
B. The item must satisfy ALL applicable 2010 FRC materials/parts use rules.
Please tell me if I am correct or not.
  #15   Spotlight this post!
Unread 23-01-2010, 20:35
Just Itinerant
Corey has found them commercially available and corrected my error.
I believe past Festo valves were not a COTS item, but custom-made for FIRST. At least as I understand it, they were a special production run specifically for FIRST and they couldn't be purchased anywhere but through the special Festo FIRST site. That would bring them under Rule <R34>. However, it's certainly something that we could get a ruling on in the Q&A. It's possible, since they were donated by Festo, rather than contracted by FIRST, that FIRST treated the Festo valves as COTS.
I'll post the question to the Q&A.
<R34> Parts custom-made for FIRST and provided to FRC teams in the Kit Of Parts for previous FRC competitions (e.g. 2006 FRC transmissions, custom-made motor couplers, custom sensor strips, FRC CMUcam II modules, etc.) may be used if the part is still functionally equivalent to the original condition and:
A. The part is now generally available as a COTS item from an accessible source, or
B. All information required to fabricate the part (e.g. complete drawings, materials list, Gerber Files where appropriate, etc.) is openly available, such that any team could fabricate the part (or have it fabricated for them).
Otherwise, such parts are prohibited from use in the 2010 competition.
New Festo valve 24v? IndySam Pneumatics 19 06-02-2010 16:31
How do I use the pneumatic Festo valves? mynameisbob Pneumatics 15 17-01-2009 18:10
2 FESTO valves on 1 spike bhsrobotics1671 Electrical 12 08-02-2008 13:37
Festo Valves 2 in manual but only 1 in KoP -- Clarification Needed Mentor 2660 Pneumatics 3 06-02-2008 14:55
Leaky Valves Mark Deutsch Pneumatics 9 16-02-2007 15:07
