Go to Post On the other hand, if the tires were marked "NOT FOR FRISBEE SHOOTER USE" I'd be worried. - Ken Streeter [more]
Unread 20-01-2010, 23:40
bobosalad's Avatar
bobosalad bobosalad is offline
FRC #2518 (Spartans of St. Jude)
Team Role: Driver
bobosalad is an unknown quantity at this point
Robot Lifting
It is pretty obvious that people are spending a lot of time into the chassis, wheels, motors and even kickers. Well this thread is to bring attention to the lifting portion of the robot. I realize that a lot of people havent started that part yet, and i also realize that others have it made. Leave ideas, pictures, plans, problems, and everything you can think of about a device in order to lift the robot at the end of the competition. Thanks a lot.
Unread 20-01-2010, 23:52
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Re: Robot Lifting
So far we have a Harbor Freight winch coupled to a AM 3 stage GEM transmission with a CIM that can seams like it is strong enough lift a small car
Eventually we will make a custom winch with the GEM but if we run out of time at least we have something.
Unread 21-01-2010, 00:08
Chris is me's Avatar
AKA: Pinecone
Re: Robot Lifting
I like it. I was thinking about using the 5th CIM with stacked GEMs for extra torque and it doesn't sound like such a bad idea.
I've got nothing else to show, other than that I've been inspired by the Pink team and the Poofs. I really have no idea how to do this. :3
Unread 21-01-2010, 00:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Robot Lifting
don't need the torque so much as you need to slow it down
Unread 21-01-2010, 00:40
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: Robot Lifting
We had the shooter concept in 2 days. The chassis in 4. Just today we had a major breakthrough on a simple way to hang and we're cadding it to check feasibility. We've spent time in every meeting so far discussing hanging.
I believe the difficulty hanging is disproportionate to the returns. Consider that if you didn't hang for those 20 seconds, you could probably get 1 more ball in the goal, rendering the hanging only really worth 1 point. Consider if non of your bots could hang, you could potential score 2 or 3 balls in that 20 seconds. Perhaps matches will be decided by a couple points, but this is NOTHING like 2007 where a single bot with a good ramp system could win 80% of it's seeding matches just by virtue of having those ramps.
Finally, the difficultly of suspending means that I doubt very many matches will see robots suspended. Even if they do manage to suspend, that extra 1 point *probably* won't be all that important: I certainly would not make it a design priority.
I look forward to someone building a bot specifically for the finale - there are ways to do it (twin ramps, lifting the other 2 robots on your team, etc). That bot could be a very valuable asset, but I don't think it's a game breaker like a good ramp bot was in '07.
Unread 22-01-2010, 10:41
BryantWebb BryantWebb is offline
FRC #1810
BryantWebb is an unknown quantity at this point
Re: Robot Lifting
The problem with scoring in the last 20 seconds is if your alliance has more than 2 points, you have 1 second to return the ball to play before you suffer a penalty. FIRST really wants teams to attempt to hang or elevate thamselves this year.
Unread 22-01-2010, 10:44
EricH's Avatar
Happy Birthday! EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Robot Lifting
Wait, what? Where do you get this information?
The 11-second minimum is in constant effect. There is no way to get less than 11 seconds according to the algorithm.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 22-01-2010, 21:55
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Robot Lifting
Here is the concept we are implementing to clamp a vertical pole.
Once clamped we will winch the back end of the robot up to the pole.
Initial tests are encouraging, though we will probably have a safety bar that can catch the platform to avoid sliding. Note the same mechanism that winches the robot also engages the clamp, using the robot weight to tighten the grip.
Unread 22-01-2010, 21:59
AKA: Pinecone
Re: Robot Lifting
Can you undo it by hand?
Unread 22-01-2010, 22:09
AKA: Dan
Re: Robot Lifting
Yes, a simple flip of the winch ratchet releases everything.
Last edited by TubaMorg : 22-01-2010 at 22:50. Reason: I can't read so I answered the wrong question.
Unread 23-01-2010, 00:53
bobosalad's Avatar
Team Role: Driver
Re: Robot Lifting
hey thanks for the picture, this is a great help of concept. Im just wondering if it can be transferred to a robot.
Unread 01-02-2010, 16:04
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
Re: Robot Lifting
how are you making the clamp engage the tubing? in the picture above, the actual weight of the clamp fingers causes it to initiall close around the cylinder. then as it is hoisted off of the cround the clamp sqeezes tighter - caused by the additional weight of the cyclinder itself. But - gravity is doing the work initially. For the robot, this mechanism would be verticle so you would have to initially get the clamp to squeeze a little around the bar before activating the winch and fully tightening it. I can think of some ways to make this happen - just curious if you have come up with something.
Also, is the plan to attach to one verticle bar or two? I am invisioning a system that would use two but I think aligning them for attachment could be very tricky given the type of clamp. Any thoughts on this?
Unread 02-02-2010, 22:43
AKA: Dan
Re: Robot Lifting
One method we considered was using a lead screw to attach to the pole. We have found, though, that the robot weight is enough to maintain a positive grip. We aren't done enough to drive yet, but we will be using V-type guides to align the gripper. Plus the gripper opens quite wide until engagement.
Unread 03-02-2010, 22:21
bobosalad's Avatar
Team Role: Driver
Re: Robot Lifting
what about using the scissor lift to attach a wench hook and have the cable go back the the robot with a wench at the end, the scissor lift would not have to be strong enough to lift the robot
  #15   Spotlight this post!
Unread 21-01-2010, 00:43
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: Robot Lifting
We are going for 3-5 seconds for BOTH cable attachment to tower bar using a latex tubing snap bar, and then fast elevation of our bot with pneumatic cable tensioning speed, having saved all of our air for the end game ( our kicker is a winder that stores bungee tension & releases at any point during the wind up for variable kick power). If you can't make this happen quickly there is little time left to help partners get off the floor. Yeah, the two points is marginal, but 5 or 8 starts looking worth it.
The initial pneumatic pull up will be supplemented by having more winder pulling available at a stronger than pneumatic force levels from our same kick winder mechanism. So, if partners can get hooked on to our deployed hanging Kevlar cables, even with a mere static hook at top of their frame, we can still hoist them up off ground using our kick winder drive pulling at 250+ pounds of lift. Heck, we will even loan them a hook to mount on their frame before the match begins!
-RRLedford
1070's 2007 Robot Lifting AznPrincess3089 Robot Showcase 8 19-03-2007 19:37
Team 192, Robot Lifting Teaser Joobacca Robot Showcase 7 02-02-2007 17:46
Lifting one vs. lifting two jgannon Rules/Strategy 1 14-01-2007 17:37
robot lifting doomsdaytank Rules/Strategy 2 14-01-2003 16:41
Lifting goals patrickrd Rules/Strategy 6 17-01-2002 17:58
