Sensitivity of Cypress board
I recently wired a cypress board to a single switch. I have good communications and everything, however the board seems to be really sensitive. If i am holding the board, all of the inputs will constantly flash on-off. On the switch that i wired, when i switch off, the light stays off on the digital display. but when i turn it on, it will constantly flash. Is this normal. I assume its just due to my poor wiring job. Anything to reduce this sensitivity, other than rewiring with solid core wires?
Re: Sensitivity of Cypress board
If you are using the extended mode, you may need to enable a pull up or pull down on the digital inputs. Each digital input can be configured to default to high, default to low, or default to nothing (aka flashy/jittery).
PS: I think this set-able pull up/down is the coolest thing since capacitive touch sensors and sliced bread. |
| Cypress Board Issues | kgzak | FRC Control System | 4 | 02-02-2010 18:40 |
| Cypress board LAYOUT | SteveD | FRC Control System | 11 | 23-01-2010 11:23 |
| Cypress board | bls0620 | Electrical | 4 | 17-01-2010 23:22 |
| Cypress Board Configuration | Geek 2.0 | FRC Control System | 12 | 17-01-2010 04:23 |
| Cypress IO board connect | SteveD | FRC Control System | 12 | 16-01-2010 16:46 |
