Go to Post Someday I will have to learn how tagging and reps work. I already know how search and brain farts work. - kstl99 [more]
Unread 21-01-2010, 14:34
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Rookie Year: 1999
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
C++ AxisCamera writeCompression
If you are using C++, there is an AxisCamera class member function called writeCompression that should allow one to set the level of compression. I'm not sure what value it takes though...it could either be 0 to 100 or 0 to 1 (or something else). The function takes an integer. Does anyone know what values are legal? I'll try to figure it out tonight, but if anyone has some info it would be nice. Thanks.
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 21-01-2010, 15:21
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: C++ AxisCamera writeCompression
why are you double posting?
1-100 optimum 20-80
If i remember correctly 100 was max compression
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 21-01-2010, 15:48
Bryscus's Avatar
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Rookie Year: 1999
I posted again so this topic would have its own thread. There are a number of people asking about the slow frame rate back to the dashboard. The writeCompression routine fills in a number in a string of characters that are sent back to the camera (which in turn ends up changing its internal parameters). I would assume that it would accept integer values (as it is much easier to represent in ASCII) and so 1 to 100 would be the most logical choice. Anyway, I'll update tomorrow.
- Bryce
