Go to Post The GDC needs to write the rules once and let the game be what the game is going to be. There's little that's fun about being told exactly how to play with your toys. - Madison [more]
Unread 21-01-2010, 14:34
dnrobotics11 dnrobotics11 is offline
FRC #2589
dnrobotics11 is an unknown quantity at this point
DS / WindRiver problem
Hey everybody,
I was successful in linking the cRIO and driver station and it says that i have comms and have robot code. I had downloaded the default code to the robot but I am unable to get the jaguars to react to the joysticks. is there anything i need to set up on the driver station (settings or changes) that will make the code work? last year i didn't have this problem but now i cant make the code do anything. Thanks for the help.
Unread 21-01-2010, 15:16
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: DS / WindRiver problem
You need to click the ENABLE button on the Driver Station.
Unread 21-01-2010, 16:15
FRC #2589
ya i know that...it was enabled
Unread 21-01-2010, 16:17
FRC #2589
anyone know of any reasons why the code doesn't seem to work?
Unread 21-01-2010, 16:18
Eric24's Avatar
Eric24 Eric24 is offline
FRC #1138 (Eagle Engineering)
Rookie Year: 2007
Eric24 is an unknown quantity at this point
Send a message via AIM to Eric24
Have you entered in your team number? That assigns the classmate a static IP that will work with the robot.
Unread 21-01-2010, 16:25
goodsky's Avatar
goodsky goodsky is offline
Programming Mentor
AKA: Skyler
FRC #1902 (Exploding Bacon)
goodsky has a spectacular aura aboutgoodsky has a spectacular aura aboutgoodsky has a spectacular aura about
If I had this problem on our robot the first things that would come to mind would be to:
Make sure the watchdog is fed. There's an indicator on the bottom left that will tell you if the watchdog has died.
Make sure the jaguars are plugged into the correct ports for the simple robot demo and that your joysticks work (I would write a simple autonomous that simply drives forwards to see if that works to make sure the jaguars are functioning)
If your problem is still there after that then keep us updated!
edit: To answer your original question about if you need to change any settings on the driver station, are you using the classmate driver's station? If so, as long as you have a green light next to robot communication and one next to robot code then you should have a connection. Also make sure you have updated it!
OINK OINK BOOM!!!
Unread 21-01-2010, 16:27
Software Architect
...I am unable to get the jaguars to react to the joysticks.
Please give more detail. What are you expecting to happen? What happens instead? Is the Dashboard display showing you anything on the PWM channels you expect to be controlling? Describe what the green Robot Status Light on the Digital Sidecar is doing. Tell us about the LEDs on the Jaguars.
What connections are there to the Jaguars, and where does the other end of those connections go?
Unread 21-01-2010, 16:29
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
Rookie Year: 2007
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
As I recall there is a display in the lower right corner of one of the tabs which shows the joysticks you have attached to your driver station. (Sorry not in front of the DS right now so I can't tell you which screen exactly). If you do not see them listed there, then it is possible that your USB hub has an issue. I know that they are new in this year's KOP but ours has died already. We swapped it out for one that I had and it works fine.
Also, goodsky mentions coding up a quick autonomous mode... I believe the default code includes an autonomous function which just drives forward, at least the C++ version does. Are you using LabView, C++, or Java?
Unread 21-01-2010, 19:19
FRC #2589
Okay thanks everyone...I am using C++ so the default code has the autonomous program already coded...the joysticks are definitely working with the Classmate since the asterisks appear next to each joystick on the driver station when you push the buttons on it....there doesn't appear to be any errors with communications...I did all of the necessary updates for the DS...I will try your suggestions and respond soon...thanks guys
Unread 22-01-2010, 11:02
FRC #2589
ok i fixed the problem...it was on autonomous mode not telo. (my error)...thanks everyone
windriver c++? yara92 C/C++ 4 14-01-2010 16:39
Windriver Scarra3 C/C++ 1 31-12-2009 03:10
problem while programming 2 bottuns in windriver mahmosh C/C++ 3 12-02-2009 12:25
Problem Downloading Program from WindRiver to Driver Station The_Laughing_ManMII C/C++ 10 09-01-2009 20:03
Problem debugging code with WindRiver LinuxMercedes Programming 3 07-01-2009 11:10
