Go to Post A Guru teaching batteries at Exide: "Do not draw your power from up here, by your terminals. You must reach down deep into your plates and pull the energy from your entire being! You must prove yourself worthy to be FIRST power cells!" - KenWittlief [more]
Unread 21-01-2010, 15:52
Haragorn Haragorn is offline
FRC #0888
Haragorn is an unknown quantity at this point
IP Keeps Changing
Our Classmate was having trouble connecting to our robot. So, we checked a few things, and found out that the Classmate's IP Address had changed to 10.8.88.5, instead of 10.8.88.10. We changed it back, logged out, logged into our Driver account, and couldn't connect again. When we logged back into our Developer Account and found that the IP Address had changed back to .5. We tried setting the address to automatic instead of manual. We logged out and back in, and checked it out. It had changed to0 manual settings, with 10.8.88.5 as the address. We were able to connect through LabVIEW, after changing the IP to automatic. Any ideas why this might be happening, or how to fix it?
Unread 21-01-2010, 16:11
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: IP Keeps Changing
...Its happening because the Classmate's IP is SUPPOSED to be 10.x.y.5. This is where the cRIO is going to try to communicate to the Driver's Station, is by sending packets to 10.x.y.5
Why do you want it to be .10?
Unread 22-01-2010, 00:35
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
The driver station application sets your IP address to the correct one for you automatically so that you don't have to. It's not a problem that needs fixing... it's a feature.
Unread 03-02-2010, 14:43
jahuber jahuber is offline
FRC #3184 (Pyrotechnics)
Rookie Year: 2010
jahuber is an unknown quantity at this point
Why does 2.10.3 step 8.a (pg 52) instruct to set the IP for the computer to be used to end in 10?
While I agree the manual 2.6 step 6 (pg 31) does state that the Classmate IP should end in 6, I find the Control Systems Manual confusing on this point, as the step-by step instructions for 2.10.3 step 8.a (pg 52) instructs to set the IP for the computer to be used to end in 10, which one assumes to be the drivers station (classmate) since all of the preceding steps are about setting wireless communications with the robot. For a rookie team having connection problems and trying to follow instructions to the letter, a very unfortunate diversion from discovering the "real" problem.
Unread 03-02-2010, 14:58
Rookie Year: 1997
If the documentation says to set the classmate to .6, then it is wrong, plain and simple. The selection of .10 is just some number that won't conflict, assuming it's not a computer that it already on the subnet (such as the classmate). The real problem appears to be that the documentation about this topic was not updated from last year very successfully.
Unread 03-02-2010, 15:19
The classmate's IP is supposed to be 10.x.y.5. This is because it is the driverstation, and the driverstation MUST be at 10.x.y.5 for the cRIO to talk to it. The control system manual tells you to set up the router to hand out DHCP addresses starting at 10.x.y.10, and the first development PC (assuming you're not using the classmate for development) would get 10.x.y.10 from the router. I suspect that this is what the manual meant for you to do. It was however, a bit ambiguous in how it explained it.
Unread 03-02-2010, 16:01
Rookie Year: 1997
It is actually so that the FMS can talk to the DS, not so that the DS can talk to the cRIO.
Compressor fuse keeps blowing Doug G Pneumatics 7 20-02-2007 06:32
Labview keeps freezing SHerpich LabView and Data Acquisition 31 02-02-2006 14:53
Time keeps on ticking /)/)/) archiver 2001 2 23-06-2002 22:12
