Cylinder damage with high kinetic energy?
Is this a concern for 2010 kickers?
I talked with Bimba to see what they thought. A gal in support said that the cylinders should be limited to 20 ips independent of bore size used. She said that the cylinders on the First list had no internal rubber stops to absorb energy. I asked if the load mass mattered... surely a 20lb mass would be more damaging than a 1 lb mass if traveling at 20 ips. This didn't seem to concern her so long as the 20ips was held. So I'm thinking most of us are exceeding these limits and therefore should include external stops to preclude piston hammering. I'd like to hear peoples opinions on this. |
Re: Cylinder damage with high kinetic energy?
I highly doubt many of us are exceeding 20 inches per second
B) Yes, your mechanism should NOT allow the cylinder piston itself to be the stop. That can break the cylinder. Add an external stop, JUST before the stroke causes the piston disc to hit its end plate. C) IMO, another solution is to just to - use the cylinder to "[MaleChicken] a spring" to a catch (the CDF editor won't let me use the "Naughty Word" term! <lol>). - disengage / back the cylinder off to its Rest Position. - NOW release the spring with a second tiny cylinder (or other device), by pulling a pin. A bit more fab and a control ritual, but it saves a LOT of wear and tear on your cylinder because it is not DIRECTLY involved in the firing of the device itself anymore. - Keith |
| pic: Aiming High with Balloons! | Pat Arnold | Extra Discussion | 7 | 19-06-2006 08:21 |
| Question about rules: Does ball damage count as field damage? | Jevin H | Rules/Strategy | 11 | 17-01-2006 14:21 |
| Wheeler High Breaks Bread With Wheeler High | dangerousdave | Championship Event | 0 | 20-04-2005 23:28 |
| Team 781: The Kinetic Knights- Website and Forums | GAT-X105 STRIKE | Website Design/Showcase | 0 | 31-03-2005 14:26 |
| Team 781, Kinetic Knights | MaxTheFlame312 | Chit-Chat | 2 | 30-04-2002 15:55 |
