Go to Post My calculations indicate that the game will involve pouring large areas of concrete and waiting for it to dry. Field reset should be interesting. - DampRobot [more]
Unread 22-01-2010, 23:33
Joe Finkel Joe Finkel is offline
FRC #0369 (High Voltage)
Team Role: Coach
Rookie Year: 2000
Joe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura about
Re: Solenoid is teh fail
Mark, when you mention the SMC SY3000 solenoid,you probably also meant
that it has to be 24v as well?
Unread 23-01-2010, 00:00
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Hi Joe,
It doesn't have to be, but you do probably want to chose all 12v solenoids or all 24v solenoids if you can afford what you need to buy.
If a team has really tight $, then there are a lot of combinations of 12v & 24v solenoids that are possible this year.
One Solenoid Bumper can only support one or the other voltage.
We are allowed two Solenoid Bumpers though, and one could be 12v while the other could be 24v. In addition, 12v solenoids can be driven through the Digital Sidecar Relay outputs w/Spike.
Originally Posted by AndrewJS View Post
1) The old 2009 festo valve works when manually testing it. It was wired into the 12v power supply (not 24). When testing with the sample program "simple solenoid example," an orange light lit up on it, but it did not actuate. We double checked the wiring and the plumbing to no avail.
This test bothers me, because the 2009 Festo was wired differently than earlier years. The results you saw could easily mean the 2009 Festo wiring was on pins 1&2 rather than 1&3, or vice-versa.
Unread 22-01-2010, 23:48
efoote868 efoote868 is offline
foote stepped in
AKA: E. Foote
FRC #0868
efoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond repute
Originally Posted by TD912 View Post
We're 99% sure everything is connected correctly, including the 12/24v issue.
A guy I work with was telling me about one of the supervisors he had many years back. He quoted him as saying - "Gene, don't give me this bull about how you're absolutely sure. You're a goddang engineer, leave yourself some wiggle room. From now on when I ask you your name, you'd better say 'I'm 95% sure it's Gene.'"
Double-Triple check everything again, have an outside person look at it, and when you're 95% sure that its all correct and it still doesn't work, try replacing it.
Chances are if the replacement doesn't work, you shouldn't have been 95% sure.
Best of luck.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 23-01-2010, 20:24
DonRotolo's Avatar
Back to humble
FRC #0832
I just have a nagging feeling the vent port has a plug in it. I'd love to see a close-up, non-blurry photo of the valve plumbing.
IGES File of teh KOP MachineSMMC Inventor 14 22-01-2009 20:16
Slow down teh motors! brennerator Programming 21 18-01-2007 23:30
RED SOX FOR TEH WIN!!! Heretic121 Chit-Chat 56 28-10-2004 23:00
Opinions of teh TV feed Wetzel Chit-Chat 4 29-04-2002 00:46
teh funnah Zeinin Chit-Chat 1 15-04-2002 15:02
