Go to Post Data is never ugly. It is only how you use it that can be. - Ed Law [more]
Unread 21-01-2010, 21:50
Matt2081's Avatar
Matt2081 Matt2081 is offline
Software Mentor, Alumn
AKA: Matt Birkel
FRC #2081 (Icarus)
Matt2081 is on a distinguished road
Axis Camera 206 Power Connection
We are trying to set up our Axis Camera and are having troubles. Is there a way to not use/take apart the wall plug portion of the power cable (included with the camera) in order to do this?
2011 Boilermaker Regional Winner
2011 Boilermaker Motorola Quality Award Winner
2010 Boilermaker Regional Finalist
2009 Boilermaker General Motors Industrial Design Award Winner
2008 Boilermaker Engineering Inspiration Award Winner
2007 Boilermaker Rookie All-Star Award Winner
Unread 21-01-2010, 22:51
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
FRC #3132 (The Thunder Down Under)
Team Role: Electrical
Rookie Year: 2010
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Re: Axis Camera 206 Power Connection
You are supposed to be able to create a wire for it that connects to the Power Distro board in the 5V WAGO plug. I remember reading a walk through but I can't remember where it is.
Hope that helps,
timytamy
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 21-01-2010, 22:54
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
You are supposed to use the cable that came with the camera....
I recall that last season, we recieved two power cables.
One came in the box with the camera, the other came in a seperate box alone. You do need to cut the power supply end off, and connect it through the 5volt power supply on the Power Distribution board next to the 5v LED on the board.
You shouldnt have any problems with it. make sure you check the polarity so that you have them hooked up correctly.
Unread 22-01-2010, 03:46
JeffChan's Avatar
JeffChan JeffChan is offline
FRC #2854 (EVHS Robotics)
Team Role: Leadership
JeffChan is on a distinguished road
Send a message via AIM to JeffChan Send a message via MSN to JeffChan
From Chapter 3 of the 2009 Control System Manual:
How do I build a cable for passing 5V power to the Ethernet camera?
• Take the camera’s power adapter (PN SA106A-0512-6) and cut the wire off close to the
Wall-Wart.
o Note: There are two power adapters for the camera included in the Kit, one in the
camera box and one separate. Use the separate one (PN SA106A-0512-6) to make
this adapter.
• Separate the wires and strip 5-6mm off the ends.
• Use a small flat head screwdriver to open the WAGO 739-302.
• Insert the positive (striped) wire in the right port. Note: the correct orientation can be verified
by looking at the silk screen on the PD Module.
• Insert the negative wire in the left port.
• Give a smart tug to verify the connection is secure.
• Power the PD, and verify that the barrel connector’s center conductor is positive
Team Website
Unread 23-01-2010, 15:06
DBortnick's Avatar
DBortnick DBortnick is offline
AKA: Daniel
FRC #1850 (Mechanicats)
Team Role: Coach
Rookie Year: 2010
DBortnick is on a distinguished road
Thanks so much, this was very helpful Jeff. This is my first year as a mentor, so I rarely think to go back to 2009 specs with my questions.
Unread 23-01-2010, 18:03
cappielloa cappielloa is offline
FRC #1099 (Discotechs)
Rookie Year: 2007
cappielloa is an unknown quantity at this point
If you don't have two power adapters and are worried about losing the wall adapter for use in the future (though I don't know that's much of a concern) you can use a few crimp connectors to make a quick connect to use the camera with both the robot and the wall adapter. Just put 2 connectors on the cut end of the wire, 2 on the wall adapter end, and 2 on a short leads coming from the WAGO connector. That's what I did for my DS radio last year.
Unread 24-01-2010, 14:41
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
D,
There was a lot of discussion here on CD last year and a search will turn up the Radio Shack part number of a connector that will work and save your AC supply for the camera. Most teams that used the camera went this route in 2009.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 24-01-2010, 15:51
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The same text is in this year's control system manual.
AXIS 206 Camera not working Wicked NI LabVIEW 14 25-01-2010 21:04
AXIS 206 camera not working Wicked NI LabVIEW 3 21-01-2010 10:05
About the 206 Axis Camera yoavh360 Electrical 8 18-01-2010 15:14
Need help with Axis 206 Power Adapter dipmeinaluminum FRC Control System 1 21-01-2009 20:01
Programing servo in Axis camera 206 frcchile NI LabVIEW 6 18-01-2009 08:53
