Go to Post It's just a game. - artdutra04 [more]
Unread 21-01-2010, 21:59
chsrobotics3283's Avatar
chsrobotics3283 chsrobotics3283 is offline
FRC #3283 (Clarksburg Robotics)
chsrobotics3283 is an unknown quantity at this point
Modified VI's question!! HELP!!
So I just modified the Joystick Input Example.vi, for 2 joysticks for our robot. My question is which folder should I put this VI into? The Team Code Folder? If so, then don't I have to modify the other VI's in the Team Code folder for both of the joysticks to work? How do you run all the programs together?
Unread 31-01-2010, 00:19
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Re: Modified VI's question!! HELP!!
Need a little more info:
Are you calling the Joystick Input Example.vi in your team code already?
If so, then
1. Open all your code that references the Joystick Input Example.vi
2. Modify the Joystick Input Example.vi.
3. Save the Joystick Input Example.vi using the File->Save As and then select Substitute copy for original. Save it to your Team Code folder. All the Vis that reference it (assuming they are open at the time of this save) will now point to the newly saved VI. I would suggest that you change the name of the new VI to something different (e.g. Joystick Input Example Team xxx) to avoid name collisions with the original Example vi. The fact that you are using a project will help avoid that, but a different name will ensure that you don't collide the names.
5. Save all the VIs that use the new VI so they remember that moved the Joystick Input Example.vi.
Basic VI's ???? chsrobotics3283 NI LabVIEW 8 22-01-2010 00:00
passing image data through vi's Christine_Ilich Programming 2 07-02-2009 15:37
LabView Functions Palette missing WPI VI's ksquared NI LabVIEW 1 31-01-2009 15:03
Using the analog sensor .vi's Hazmatt NI LabVIEW 5 13-01-2009 22:57
modified toughbox gorrilla Technical Discussion 7 02-04-2008 17:13
