Go to Post By the looks, 1114 has already figured out both #1 and #2. They're still behind 71, who is just about done with their robot for the 2012 season, is getting driver practice for 2011, and is working on their robot designs for the 2013 water game. You're still way behind. - EricH [more]
Unread 22-01-2010, 12:16
MachineSMMC MachineSMMC is offline
FRC #3026
MachineSMMC is an unknown quantity at this point
Switching to Holonomic Drive
In the teleop. VI we tried to replace the arcade drive with the Holonomic Drive. When we try to build the code it gives us an error that says to fix the Robot Main.vi. We are fairly new to Labview, all of our programmers graduated last year. Any help would be appreciated.
We started with the FRC cRIO Robot Project provided.
Thanks
Chris Tellers
Mentor
Team #3026
Orange Crush
Unread 22-01-2010, 13:07
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Switching to Holonomic Drive
In the upper left tool bar there is usually a white Run arrow.
When you have broken code the arrow becomes broken and gray.
If you click on it, it will tell you what your errors are and will actually take you to the mistake on the block Diagram.
Holonomic Drive Help star_lancer NI LabVIEW 2 01-02-2010 22:39
Holonomic drive vi with mecanum wheels dwodrich NI LabVIEW 7 18-01-2010 16:01
Holonomic drive and ramp robotaddict Technical Discussion 11 13-01-2006 16:57
Holonomic Drive Question Jeff Waegelin Technical Discussion 12 20-11-2005 21:23
Holonomic Drive Mathmatics Discussion robotaddict Programming 35 15-10-2005 13:29
