Go to Post That sound you hear is of every programmer in the country cringing at the thought. - Billfred [more]
Unread 22-01-2010, 13:29
fiferdc fiferdc is offline
AKA: David Fifer
FRC #1747 (Harrison Boiler Robotics)
Rookie Year: 2010
fiferdc is an unknown quantity at this point
CircleTrackerDemo: Servos and Gyros
I've been playing around with the CircleTrackerDemo and have managed to get an image feed up on the dashboard. There are two things that I have run into that I am stuck at.
1. In the code, it constructs a Robot Drive with channels 1 and 2 on the digital sidecar referring to some motor. Are these supposed to be the servos that rotate the camera? I currently have them both as jaguars and have modified the code to get the robot to run on tank drive.
2. In the updated dashboard, there is a dial that has degrees listed about it. I'm fairly sure that this is relating to the gyro heading. In the Java code, clusters are created that display I/O and other readings to the dashboard. Looking through it, I found nothing (I'm not saying that it isn't in there and I didn't recognize it) that would display the gyro heading on the dashboard. How is this done?
Java CircleTrackerDemo rjbarra Java 2 19-01-2010 22:56
Gyros and Accelerometers excel2474 Electrical 10 10-01-2009 13:22
Wiring Gyros and Encoders? SuspectZero Electrical 3 03-02-2008 15:30
Gyros and WPILib RyanW Programming 2 28-01-2008 14:05
Gyros and WPILib RyanW Programming 1 27-01-2008 22:24
