Go to Post While those ideals might exist in black and white perfection; in the real world, with very rare exception, they can only be implemented as compromises in shades of gray. - gblake [more]
Unread 22-01-2010, 15:16
skotmorris's Avatar
skotmorris skotmorris is offline
Windchill Product Manager
FRC #4909 (Bionics - Billerica Memorial High School)
skotmorris is an unknown quantity at this point
1 ToughBox w/2 Motors or 2 ToughBoxes w/2 Motors
I have a rookie question on the configuration of the AndyMark ToughBoxes. What is the difference between setting up a drive train with 1 motor and 1 ToughBox per wheel vs. 1 toughBox with 2 motors for 2 wheels?
The default AndyMark chassis is setup with 1 ToughBox and 2 motors, but I really do not know what the difference is and whether or not one configuration is better than another.
Anyone have an opinion or suggestion?
Unread 22-01-2010, 15:32
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: 1 ToughBox w/2 Motors or 2 ToughBoxes w/2 Motors
Adding another toughbox per side increase weight and cost, and is usually not necessary. If you are using a drive like mecanum that requires different speeds for each wheel, then it is necessary.
Unread 22-01-2010, 15:37
spectre107's Avatar
spectre107 spectre107 is offline
FRC #0617 (EngiNerd)
Team Role: Mechanical
spectre107 is an unknown quantity at this point
Cool Re: 1 ToughBox w/2 Motors or 2 ToughBoxes w/2 Motors
First you have to consider what you want your robot to do.
Do you want all wheel drive?
If you use a toughbox mounted mid-chassis to each side you'd have to use chain to transmit power to each wheel(Kit Bot), you could direct drive each wheel(1 Toughbox/1 Motor Per Wheel) then each wheel could be powered independently of the other.
Our Lunacy robot utilized direct drive and we could push 2 robots across the field last year.
We're doing the same thing this year to avoid chain, and keep our ground clearence high and CG low. Since each wheel/trans is spread out on the corners of the robot.
If you equip a toughbox with 2 motors then you have doubled the power output.
Its not really a question of which is better, its all about what you want you're drivetrain to do.
Using 2 motors in one toughbox DarKCroNo Motors 4 29-01-2008 09:09
Motors, Motors, and More Motors 1033missions Motors 1 09-02-2006 18:46
Motors.. and more motors.. How many on your 2004 bot? OneAngryDaisy Motors 33 23-02-2004 00:46
Matching Drill Motors and Fischer-Price Motors archiver 2001 5 24-06-2002 00:51
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
