Go to Post resistance to FIRST is futile. - King Duke [more]
Unread 22-01-2010, 15:24
Josh987's Avatar
Josh987 Josh987 is offline
That's what I say.
AKA: Josh
FRC #1565 (Think Tank Tech)
Josh987 is an unknown quantity at this point
Axiscamera.h not found
I was trying to build the camera example provided with the windriver frc examples and when ever i did it would come up with several errors, basically saying it can't find some .h file pathways and others don't exist. All help is much appreciated.
Charlieeeeee, Candy Mountain
Unread 22-01-2010, 15:32
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Re: Axiscamera.h not found
They are in a sub-directory so do this:
#include "Vision2009/AxisCamera.h"
Unread 22-01-2010, 15:48
Josh987's Avatar
That's what I say.
AKA: Josh
Thanks for the quick response. That got rid of a few of the errors i attached the rest of the errors in a notepad file that is attached.
File Type: txt error.txt (952 Bytes, 14 views)
Unread 22-01-2010, 17:21
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Add #include "ErrorBase.h" right before #include "PCVideoServer.h"
Add #include "WPILib.h".
that did it for me.
BTW, Workbench capabilities helped me find these in about 2 minutes.
Double click on "ErrorBase" in the file PCVideoServer.h, then right-click, then scroll down to "Open Declaration".
That showed me where ErrorBase was declared.
For the Wait function call, tried the same thing and it wasn't found.
In that case, use search through workspace to find it.
In either case, verify that those include files were not included and then choose where to include them.
Workbench has very powerful code comprehension and navigation tools.
Use them.
It looks as though just including WPILib.h would have been sufficient, since it includes ErrorBase.h.
Workbench won't make these judgment calls for you, as illustrated here, one has to take the time choose the best remedy. ;-)
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 23-01-2010, 14:33
Josh987's Avatar
That's what I say.
AKA: Josh
I wasn't aware of the various tools you were referring to I will be sure to use them in the future. I won't be able to test this until Monday but it looks as if I won't have any more problems. Thank you very much for the help.
G++ not found BrandonD-1528 Programming 5 03-02-2009 15:36
Nirio_device_open not found. teshazman NI LabVIEW 1 17-01-2009 21:00
Camera not found! SpeakerSilenced Programming 0 21-02-2005 12:54
Camera not found!!! Code\\Pilot Programming 11 02-02-2005 00:04
Header Not Found (adc.h) NotQuiteFree Programming 2 23-01-2004 16:26
