Go to Post If this was really about changing the culture, FIRST would be on Will.I.Am's website. - Meredith Novak [more]
Unread 22-01-2010, 16:42
Dakabt's Avatar
Dakabt Dakabt is offline
FRC #2526
Dakabt is an unknown quantity at this point
Controlling the camera with a joystick
Hello I was wondering how (if possible) I would be able to allow a joystick to be used to control the camera on the robot.
Unread 22-01-2010, 17:18
lscime lscime is offline
AKA: Luke Scime
FRC #2614 (Mountaineer Area RoboticS (MARS))
lscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to behold
Re: Controlling the camera with a joystick
Assuming you mean that you want to move the servos on the camera mount using a joystick, yes it is indeed possible.
We've been playing around with such control for about a week. Here is a one method in LabVIEW. Essentially you can tell the servo "goal" position to increment by 1 (or another value) every time the main loop loops if a certain condition is met (i.e. a joystick in a particular position). The servos will constantly goal seek on this new position. We accomplished this by storing the "goal" position in a shift register and incrementing/decrementing/not changing this value depending on a case statement triggered by a joystick.
Again this in LabVIEW but the same principle should apply in Java and C.
Hope this helps,
Student Programmer, Team #2614.
Unread 23-01-2010, 04:34
non847 non847 is offline
FRC #3089
non847 is an unknown quantity at this point
how about setting the angle of the servos proportionate to the axes of the joystick? works great!
Unread 24-01-2010, 14:24
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
This requires you to hold the joystick in a non-centered position if you want the camera to be anywhere but centered.
Unread 31-01-2010, 20:13
psychomonkey psychomonkey is offline
Mr. February
AKA: Seth Rhodes
FRC #1592 (Bionic Tigers)
psychomonkey is an unknown quantity at this point
So, if I understand correctly, In order to run this code, it must be in a while loop INSIDE the initial teleop case structure? I tried doing this and every time, I would get a watchdog error. I know that I didn't have a shift register. Do I need one on each side of the loop?
In a time... When the greatest comeback occured... There was... MR. FEBRUARY!!!
Unread 31-01-2010, 20:38
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
No while loops inside while loops.
Use a shift register and put the code in the main loop.
Kettering Motorsports
Unread 31-01-2010, 21:06
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
You can also do without the shift register. Since the FPGA knows what value you've set the servo to, you can use a Get Angle or Get Position vi to retrieve it, apply whatever modifications you wish to the value, and give it to a Set Angle or Set Position vi.
(If you're changing the value by extremely small amounts, you might need to watch out for rounding errors in the conversion between servo position and PWM value.)
Unread 31-01-2010, 23:20
Mr. February
AKA: Seth Rhodes
I'm not doing that. In the code this year, the teleop is all inside a case structure. Can I place a while loop inside a case structure?
Unread 31-01-2010, 23:26
Mr. February
AKA: Seth Rhodes
You know what, I just realized that you were referring to the robot main.vi, not the teleop.vi. My apologies. So instead of using the while loop, I should just use comparison vi's on the joysticks to lead to increment vi's inside case structures?
Unread 01-02-2010, 21:51
Mr. February
AKA: Seth Rhodes
Got it, thanks.
Camera servo control off of the Joystick axes m3rc1l3ss NI LabVIEW 5 13-03-2009 20:00
Moving Camera Servos With Joystick Button DWirth NI LabVIEW 7 26-02-2009 21:35
Problem with the joystick Asmos NI LabVIEW 5 23-01-2009 09:40
Servos controlling camera and purple screen ryan_f Programming 6 17-01-2006 23:21
controlling with the radio Lord Nerdlinger Programming 2 17-02-2004 22:40
