Gyro broken on WPILib 2010?
Trying to grab the angle from the 2009 KoP gyroscope causes a fatal exception. I'm using the most recent WPILib release (1/09/2010) with the latest cRIO firmware (v19).
Do any of the WPILib guys have any idea what the issue is? Stack trace in Wind River debugger: Code:
FRC_RobotTask : 0x1d42590 (Stopped) nFPGA::nAD9A5591CC64E4DF756D77D1B57A549E::tAI::getSystemIndex() - tAI.h:22 AnalogModule::GetLSBWeight() - AnalogModule.cpp:401 AnalogChannel::GetLSBWeight() - AnalogChannel.cpp:135 Gyro::GetAngle() - Gyro.cpp:153 Rambot::TeleopPeriodic() - Rambot.cpp:243 IterativeRobot::StartCompetition() - IterativeRobot.cpp:139 RobotBase::robotTask() - RobotBase.cpp:130 vxTaskEntry() - 0x001a020c |
Re: Gyro broken on WPILib 2010?
Interesting. Can you please post or PM your code so I can attempt to debug the issue and fix the problem. I'm not seeing anything at first glance that would cause this, but perhaps you are using the class differently that I am. I'm guessing that "this" is NULL or something when calling getSystemIndex(). The m_module pointer should be initialized in the AnalogModule constructor. Anyway... a look at your code should clear things up.
Thanks, -Joe |
| Where to find a Gyro and Accelerometer Sensor Board for 2010 FRC? | xSpongeX | Sensors | 4 | 01-18-2010 06:17 AM |
| Sources for 2010 WPILib? | Mike Mahar | C/C++ | 6 | 01-11-2010 11:02 AM |
| broken gyro | captainking | Electrical | 0 | 02-02-2008 09:16 AM |
| WPILib Questions | Kruuzr | Programming | 1 | 01-22-2007 11:46 AM |
| Broken promises or BROKEN ROBOTS! | archiver | 1999 | 9 | 06-23-2002 10:18 PM |
